G'Day Guys
I'm looking to buy a Rear Seat Backing Board, the one that sits between the seat and boot.
It must be in good condition.
Please PM me if you have one.
James
Rear Seat Backing Board Wanted
James
WOWU
Penrith NSW
James
WOWU
Penrith NSW
Re: Rear Seat Backing Board Wanted
you can get new ones from Rares if your willing to fork out what they want for them...
http://www.rarespares.net.au/rarespares ... duct=H1175
Nathan
Nathan
Foundation Member
Foundation Member
I'm going to make my own out of 3mm mdf. I've also seen some cars that have used checkerplate
yep... someday...
Thanks Nathan & Jarvo
I did'nt know Rares had the rear seat backing boards, thanks for the heads up - they are over priced
your right Nathan.
I need to get a half decent one to use as a template so I can make the rear seat backing boards in 3mm Alucabond composite panel it's aluminium both sides, I have Red, Green and white panels in stock with a black internal core layer.
I will also be doing door trims once the templates arrive.
I was at Blacktown Rares last week trying to buy the FB door trims and the guy told me that they're cutting back on the FB EK stock, so I got the trims from Betta Auto Rubber in QLD.
The girl I dealt with there was really cool and knew a lot about FB and EK's, she and her boyfriend are Mangus on this forum.
I recon we should all support them - great service
your right Nathan.
James
WOWU
Penrith NSW
James
WOWU
Penrith NSW
Why not make your own template especially if you're planning to use something completely different from standard. A basic template can be made from a piece of cardboard easily enough.
Also it might help if you fill in your details so people know what area your from as someone close could possibly do a short term loan of one.
