138 GREY MOTOR
goats1
138 GREY MOTOR
Post by goats1 »
HI GUYS, I HAVE HAD MY GREY 138 REBUILT AND FIRED IT UP RUNS SWEET AS BUT WHEN I BRING UP THE REVS IT HAS A WHURRING NOISE SORT OF SOUNDS LIKE A SUPER CHARGER IN THE SOMEWEAR I HAD THE ALI/STEEL TIMING GEARS PUT IN IT WHEN IT WAS DONE,ONLY CAUSE I DONT TRUST THE FIBRE ONE, {HAD TROULBE BEFORE WITH A COUPLE OF THOSE ONES} NOT SURE IF THIS IS THE NOISE OR NOT ANY IDEAS,HAS GOOD OIL PRESSURE ,ROCKER COVER OFF PLENTY OF OIL COMN OUT OF ROCKERS ETC ,ANY HELP WOULD BE GREAT CHEERS GOAT
goats1
Re: 138 GREY MOTOR
Post by goats1 »
Thanks Tim i was all worried ,yes they replaced both with the steel/ali {which eva they are} so if i was to replace the big one againe with the fibre one should be quieter cheers GOAT
