Spatman's Ute
samprinci
Re: Spatman's Ute
Post by samprinci »
:thumbsup: :thumbsup:
www.fbekholdennsw.com
Cobber
Re: Spatman's Ute
Post by Cobber »
Pulled out the bottom section of the firewall and tacked in a better one from the panelvan. Need to tidy things up a bit more and then tack in the replacement floor panels and larger trans tunnel. I will fix up the crossmember under the floor before doing the floor sections. Anyway, attached a few more photos.
Re: Spatman's Ute
Good stuff Cobber. 8)
Cobber
Re: Spatman's Ute
Post by Cobber »
Time to ad a few more pic's. Wheels finally turned up for the ute, very happy with them, now need some whitewalls to go on them.
Gave the SCW front end a coat of paint the other day. Used the KBS chassis coat kit, very easy to use and very happy with the result.
Tunnel and floor pans ready to be tacked in as well. will tidy up the crossmember first though and make adjustment so that it follows the bigger trans tunnel.
Bonnets also ready for some undercoat.
Anyway, enjoy the pics.
michaeljohn1234m
Re: Spatman's Ute
Post by michaeljohn1234m »
cobber what (who's) front end is that, it looks good and the wheels like great,will be nice on the car-keep it up,who needs sleep anyway
muza
Re: Spatman's Ute
Post by muza »
Lookin good mate :thumbsup:
Stock as a rock
Not so stock
Marty K Bird
Re: Spatman's Ute
Post by Marty K Bird »
Looking good man!! Love those wheels and that front end too!
Keep up the good work.... and the updates!
:peaceout:
Cobber
Re: Spatman's Ute
Post by Cobber »
Thanks for the comments guys. Feels like a little progress has been made. Can't believe its been 2yrs already since serious work began on it.
Michaeljohn1234m, the front end is by Heath at Southern Chassis Works. Have a look at the Mick's Ute thread to see some of his other work.
Re: Spatman's Ute
Post by Mick Jagger »
lovely welding/grinding work
looks neat as
what are the rims?
kmawic
Cobber
Re: Spatman's Ute
Post by Cobber »
Thanks Mickjagger, with so much welding and grinding to do, one would hope they improve a little with time.
The wheels are crager deluxe 69's.
Cobber
Re: Spatman's Ute
Post by Cobber »
Good Evening Everyone. Waiting for it to cool down a bit before I go to the shed and start playing again!!!
So thought I would post another couple of pic's of what has happened this week.
Let me know if the pic's aren't interesting enough and I can not post so many.
Had a kink in the subframe I had to get out, so cut a section from my donor subframe and welded that in and then put the first strengthening plate on. Should get the other one on over the weekend if I get time after carting some hay to keep the sheep and horses going.
Then it should be ready for a lick of paint.
Picked up a really neat tool for cutting the spot welds, goes on the drill, don't know if anyone else has seen them. I will post a picture next time.
michaeljohn1234m
Re: Spatman's Ute
nice job tim, i had to die grind the holes on my strengthening plates so the rubbers fitted properly,how did yours fit,and keep the photo's coming
vintageholden
Re: Spatman's Ute
Post by vintageholden »
looking good mate..
looks no rustier?? than mine yet no interest..its for sale....
:yeahhh:
Cobber
Re: Spatman's Ute
Post by Cobber »
Good Morning to you all :D ( I am definitely not a morning person).
I managed to get the second strengthening plate welded on to the subframe during the week and put rust converter on it.
Only had to die-grind the single bolt hole on the leg of the plate a little to make them fit properly michaeljohn1234m which was good.
Pulling subframe out of the shed so the little fella could help blow it down allowed me time to clean up the shed a little.
Pulled out the spray gun yesterday afternoon and put a coat of KBS chassis gloss black on it.
After so many hours cutting welding and grinding, you get a fair kick out of putting some colour on parts :) :) .
Will put a second coat of paint on this arvo.
Anyway, check out the pic's.
Little Helper, he wanted to work on the tractor in the background but the air hose wouldn't reach that far!!
muza
Re: Spatman's Ute
Post by muza »
Brand new again! :thumbsup:
Stock as a rock
Not so stock
