Removing scuttle panel
ekwags62
Post by ekwags62 »
Need to do some repairs to the scuttle panel. Do I need to remove the windscreen to reove the panel.
Also how do I remove the stainless trim from the rubber.
Thanks in advance.
Mick.
Yep you will need to remove the screen. As for the chrome that is fed into the rubber before it's put around the glass, so it'll come out with the screen, provided of course you have taken the two corner and centre pieces off.
ekwags62
Re: Removing scuttle panel
Post by ekwags62 »
Thanks guys. Obvious design came before functionality
