Daves EK
Re: Daves EK
Looking good mate :thumbsup:
ekdave1962
Re: Daves EK
Post by ekdave1962 »
fitted ve steel rims with some new rubber, maybe a set of moon disks , book paint booth for next week so she finally getting there ,,
neatride
Re: Daves EK
Post by neatride »
Looks Great Dave :thumbsup: :thumbsup: :) 8)
Yes dear, just like you said. Theese are the words of an understanding marrige.
rosco
Re: Daves EK
Post by rosco »
Nice work, Dave - hope you are coming to Wang...?
ekdave1962
Re: Daves EK
so do i rossco, theres every chancethat ill have a car that will make it there :-)
searsy
Re: Daves EK
Post by searsy »
seriously go back to page one and remind yourself of what you started with.
Top job fella
michaeljohn1234m
Re: Daves EK
Post by michaeljohn1234m »
ImageImage]Image[/quote]
steering shaft modified commodore bonnet hindges due the using vn booster
dave do the bonnet hinges work well and how hard was it to get them there as i'm thinking of doing the same with a vs booster
muza
Re: Daves EK
Post by muza »
searsy wrote:seriously go back to page one and remind yourself of what you started with.
Top job fella
Here here!!
Amazing job mate!! :thumbsup: :thumbsup:
Stock as a rock
Not so stock
ekdave1962
Re: Daves EK
mich the hindges work ok but i also needed to trim the rear edge of bonnet as it rotates on a different axis when opening that caused it to catch.
if i was doing another i would spend the $$ on a smaller booster and avoid all the work on hinges and bonnet, did consider those 8" units on ebay there around $250 chromed with master cyclinder and may even change to one of them down the road to add a little bling under the hood ..but that means i need to find another bonnet if i choice to change back to orginal hindges ..
most likely wont bother as i have the 41 chev trucks waiting for there turn :-)
michaeljohn1234m
Re: Daves EK
ekdave1962 wrote:mich the hindges work ok but i also needed to trim the rear edge of bonnet as it rotates on a different axis when opening that caused it to catch.
thanks dave for your advice i was talking to an engineer about a gemini booster and he was not impressed and wanted one out of a simmar size car other wise he wants a brake test $$$$$$
I'll give hoopers a call and find an engineer who's done an old holden i hear Athol Mullen has passed rods so i'll try him as i've been looking at the new 7'' units, will the 8'' units fit
ekdave1962
Re: Daves EK
hi mich, not sure about the 8" unit but the should fit i used a vn unit simply because i had it but the vr unit are a but smaller and should keep engineer happy
some guys fit there booster into the clutch spot and modify the pedel to suit, depends if your running a manual or auto, my mate eh has it fitted that way and allows for normal hindges , so that could be a better option ,, as for brake test im sure that have to be performed regardless of brake mods there just a fact of life , i think hopper recomend a nissan master with a remote booster ..
michaeljohn1234m
Re: Daves EK
ekdave1962 wrote:hi mich, not sure about the 8" unit but the should fit i used a vn unit simply because i had it but the vr unit are a but smaller and should keep engineer happy
mines an auto so i do have the room i'm using a vs booster i got today and the brake pedel so i just mod it to fit-just like to know were my engine sits first
ekdave1962
Re: Daves EK
yeah i think the Vn booster may be bigger .. i positioned mine in the clutch spot and it was too close to motor for me ,,
michaeljohn1234m
Re: Daves EK
I just had a look and took the springs off that gets me in the middle of the two,now i'll check inside with the VS pedal braket on the weekend
ekdave1962
Re: Daves EK
ok a lick of paint , not for the fun job of blocking it all back again and a few flow coats .
Moon disks arrived
