G'day Folks.
Any ideas on what I can use for the rear end panel rubber, The thick broad rubber that is fixed to the lower rear beaver panel and the rear tailight assemblies, it is concelled between the Rear bumper bar. I'm getting a little tired of the crap that oozes out from under the rear bumper bar and messing up the rear end, along with the stone chips, being deflected. I have tried truck tyre tube, but doesn't stop it.
Any tips or tricks would be appreciated. Expander foam seams like a good option, if I can get in there to shape it right.
Regards John
Any Ideas.
Gday John
Truck tube rubber would be too thin, the air being scooped up by
the lower edge of the bumper, would blow the tube rubber out the way.
The rubber would need to be 1/4" thick to hold its position.
I know the original rubber was thinner, but it was moulded to hold its shape.
You could make a metal one out of thin galv' sheet,
you can't see it when the bumper is fitted.
Jeff
Jeff
rubber replacement
Thanks
Dan
dan
