Rear springs
Rear springs
I'm installing the rear leaf springs. Fitted up front pin finger tight. Then did rear hangers.
How do I push/pull the front pin through?
Way too tight to use the nut to pull it through...I think I've already stripped one side... :roll: :oops: :evil:
Stewart
Re: Rear springs
that's all i've ever done is pull through using nut
is it a new bolt?
sorry can't offer more than that
Re: Rear springs
New repro pins Mick.
Having walked away and calmed down... :roll:...I think I'll have to remove the pin and do a 'test fit'...probably should have done that in the first place... :roll:
Re: Rear springs
Put the pin rite through first (i would be more inclined to hit it through with a hammer rather than relying on the nut to pull it through) there will be less pressure on it, then do the rear hanger.
Re: Rear springs
Thanks Trev. The hammer has been out...
Just pulled the pin out...
A test fit in 'reverse' - putting the head of the pin through first...there is no way it will going to fit...without shaving some metal off the head of the pin.
NOTE TO SELF - test fit everything before fitting... :)
Re: Rear springs
parisian62 wrote: NOTE TO SELF - test fit everything before fitting... :)
Likeb the monkey with the nuts :lol: .
Re: Rear springs
yup.
Re: Rear springs
spot the difference...
Re: Rear springs
No step in yours?
Re: Rear springs
one is a drwaing, one is a real bolt :? :oops: :ewink: :ebiggrin: :lol:
It does have the step down just not as big as the pictured one. Although it looks like there is more thread.
rosco
Re: Rear springs
Post by rosco »
You and a hundred others, Stewart....... we place our troth in replacement parts.... surely they know what they are doing...?
Sadly, a lot of this comes up....
Can you please tell us the difference in shaft boss length - if your issue is as a result of this, I would be making contact with the supplier.... - good faith, the onus is on them to rectify/correct supply.....
I hope that hammer was a "wheel tapper" not a sledge......
Oh, and by the way - what have I done to you...? your paintwork and attention to detail under there is magnificent....... tyre looks a little "ho-hum", however (sic).
Re: Rear springs
you're right Trev...and so is DR ....and so is Mick :lol:
There is slighly more thread (2-3mm) but the overall pin length is shorter. Just enough difference to make it a real pain to fit. I had to file down the shaft a bit. Got there in the end.
Roso - no sledge hammer... :shock: but a few good whacks with a hammer though. I'm really happy with the way the underside has turned out. I can't claim to laying down the paint that would be Dave (Bootlegger on the forum). No tyre under there yet - I think you can see an old towel draped over a stand of bricks.
Stewart
rosco
Re: Rear springs
Post by rosco »
I suspected my spectacles were reaching their terminal date.... you have just confirmed it.....
Tyre would have been on the other side of the spring, and only a tyre-wall visible...
Releived to learn that you haven't widened your rear track...
