Got all the bolts off from below and the side mounts......few more on top...? Any special tricks to pull the box off...?
PS< There is a special place reserved in hell for the prick that decided where to put the three starter motor bolts on a grey motor!!!
Removing Gearbox from Grey
The Kardinals, Melbourne.
Re: Removing Gearbox from Grey
if you don't want it to just slam on the ground stick a jack under itMai Ki-Ki wrote:Got all the bolts off from below and the side mounts......few more on top...? Any special tricks to pull the box off...?
the bolts they're not great but there's far worse
Assume the tailshaft is out and the box-end plugged (or drained onto the garage floor
). Helps (more than a bit) if the motor is free to tilt - drop the radiator top hose, open the bonnet and watch nothing hangs up as the box slides out.
Then wiggle wiggle (swear)... repeat.
Getting them out seems to be a crapload easier than getting it back in though
Did more benchpressing than a Schwarzenegger workout.
