What steering column
DOLLER
Re: What steering column
Blacky are those columns colapsible???
What else should I be looking for in a column to fit it up to a torana R&P?
Not sure - give them a call on 08 94951932DOLLER wrote:Blacky are those columns colapsible???
depends what yor rego requirements are you may not even require collapsable depending on engine size, only thing that might be an issue with these collums but not a big drama is intermediate shafts as the torana has a quite small shaft out of the rack these collums have a large splined or "D"ed shaftDOLLER wrote: What else should I be looking for in a column to fit it up to a torana R&P?
DOLLER
Thanks Harry.
I know that I need a collapsible column, and if there is not an adaption coupling, they shouldn't be too hard to fab up.
AAP will be able to supply a coupling from the column to either a splined shaft or a double D shaft .
The guys name who does the collapsable fb column is George Windus you can call him on 0421053733 ...I have just ordered one thru him.... not cheap but its legal and engineered .....you need to give him a steering column from a hq or similar and the top of the fb column ....for your money you get a steering column modified to hook up to any size shaft on your steering rack the honey pot welded and machined and primer etched and uses the standard fb indicator mechanism and all the engineering paperwork to get reg approval ...and this is the greatest problem you can have if not engineered correctly ...if you havent spoken to an engineer before you do any modification you could waste a lot of money and time ...,my engineer wants collapsible column with V8 conversion he will accept non collapsible on red motor conversion this apparently is a requirement in Victoria by Vicroadssteved57 wrote:Mini
When I was considering using the Hadfield (or CRS) front end I spoke to one of the guys there who told me that a bloke who works there makes collapsable FB/EK columns "on the side". The guy on the counter was happy to provide me the contact details but I didn't take 'em at the time. I'm sure they'd still be happy to provide the details though. As I recall the columns were only a couple'a hundred bucks - but don't quote me.
Alternatively Rods Racks (Rod Gordon Smith - 0419 760 987) does modified columns too and i'm sure they're nowhere near the price you've been quoted.
Cheers, Steve
Thanks mate ...hope this is not too late
Fingers
The AAP ones are not collapsable - if you fit one into a rod and use more than 2 unis then it doesnt need to be
in NSW that depends on engineer, some will accept this most won'tBlacky wrote:if you fit one into a rod and use more than 2 unis then it doesnt need to be![]()
Ring Coates hotrods they sell a new stainless steel collasible collum for 650 ive got one for my rod they look awsome also good to buy local
regards fatboy
regards fatboy
DOLLER
What about these? Anyone seen/used one? There is a couple diff ones on evilbay.
http://www.ebay.com.au/itm/HOT-ROD-32-S ... 4aaa743b67
DOLLER
Just spoke with Coates- $750. Good lookin unit but pretty exxxy. Any other after market colapsibles out there?????
