FB, HR F/E Power steering, Any updated info?
Aussie Bob
Re: FB, HR F/E Power steering, Any updated info?
Post by Aussie Bob »
oldnek wrote:
Steve Jackson wrote:I have an EK with original power steering if you need to take a look at the setup!
Steve
You should post some photos of the set up Steve, I would be pretty interested in how they did it back then. The only other power steer system I have seen pre 60 was where a fella modified a Compact Fairlane pillar ram setup. Worked well for low speed but no good at road speeds.
Hi John, as soon as I can will start a thread. The car will be at the Nationals.
Steve
oldnek
Post by oldnek »
I'm very much looking forward to seeing this EK Proto Prem, I always thought that when Holden had the first auto in the EK, why not make a 8) smansy prem to go with it.
Aussie Bob
The thread is here ....
http://www.fbekholden.com/forum/viewtop ... 11&t=13290
I will take a pick of the ram when I get out there next.
Steve
sgo
Post by sgo »
With a bit of mucking about; instead of modifying a rack, you can modify the front end to suit the rack.
bat53retro
Post by bat53retro »
g,day i dont understand :? why not just mount the rack in the right position then you will only have approx 10 mm bump steer overall (which is about 1/2 of original
cheers bat
sgo
Post by sgo »
Second pic shows lining up rack ends with bottom pivot point.
I couldn't see how you can do this just by positioning the rack alone?
Then you mount the rack at the right height and you end up with about 1mm in bump.
Cheers.
bat53retro
g,dayset my rack up with wishbones level ,gave it to the engineer without springs and shocks ,2" of travel up an down have 2. 5 mm of bump steer
cheers bat
