If anyone is wanting shortened Polyurethane HR Holden front end bump stops they can be bought from this place www.fulcrumsuspensions.com.au and available under part number SPF0147K "Super Pro " shortened bump stops.
They will give you an extra 1 inch in suspension travel over the standard height HR Holden bump stop rubbers, so if your lowered HR front end is currently sitting on the bump stops ( standard ones) then you may be able to gain some extra suspension travel with these shortened ones.
I got mine a few months back from one of fulcrums dealers near Newcastle but they'd be available from any dealer if you quote the above part number.
Price was $63 for 4 bump stops and they are a very pretty purple colour!!
Just thought I'd wack this info up in case anyone wants some.
P.S. They don't fit kingpin front ends but I was advised by the dealer I bought mine from that they could get custom made shortened ones done if I supplied a kingpin bump stop for reference and specifications as to how much shorter I wanted one made.
HR Front End Polyurethane Shortened Bump Stops
Re: HR Front End Polyurethane Shortened Bump Stops
Are tops and bottoms the same???
