Torana steering - which rack?
Hi guys
Does anyone know if Torana front mounted steering racks from LC to UC are the same and, if not, which is the best model to use on a HR front end?
Cheers, Steve
Cheers, Steve
Re: Torana steering - which rack?
The LH was the rack they used for most of the conversion around including CRS, i'm not sure if LC/LJ are same length but i'd guess they would have a slighly narrower track the LH-UC.steved57 wrote:Hi guys
Cheers, Steve
i've used both and i think the LC/LJ rack was better but we had to make extensions from the rack end to the tie rod end
Hey guys sorry to hijack this thread but I thought one of youse would know the answer (ratbox).
How should these torana racks be greased/lubed??? Would I take off the two "plates" and grease with a heavy type of grease like axel grease??
That plus remove the boots and wind in/out while greasing i guess ?DOLLER wrote:Hey guys sorry to hijack this thread but I thought one of youse would know the answer (ratbox).
Yeah gotta put new boots on so i'll do that too.
A bit hard to explain, but what is the little phillips head screw in the cast section for?? Oil hole?
A Torana forum might be the place to ask.
Thanks guys. Looks like either will do the trick.
Cheers, Steve
Cheers, Steve
hi does anyone have any pics with a uc lj rack installed ( mrs ratbox?).
Does anyone know if the torana racks are different ie; v8 or 6?.
