RADIATOR
Bigbird
- Contact:
Re: RADIATOR
As far as I am aware you will need to run a larger radiator that will require the side panels to be cut back. I know that Aussie Dessert Coolers does a triple pass radiator for a V8 or Red motor into FB-EK but I am not sure of the dimensions.
www.drive1.net.au
www.thedrive1team.blogspot.com
www.facebook.com/pages/Melbourne-Australia/The-Drive-1-Team/401541923693?ref=ts
Re: RADIATOR
Any radiator will fit........ if you make it fit
If you don't want to cut up the car give Aussie Desert a call and see if their radiators will do the job, I have an LC/LJ Radiator in my FE and that keeps up with my warm 202 just fine as long as there is good air flow.
Re: RADIATOR
I've just had my radiator redone for my EK with a red. It was a 2 core but now its a 3 core and I can't fault it! Some trimming is required to fit it and 4 holes need to be drilled. Any competent radiator place can do a 3 core (heavy duty version). Mine cost $350 to get done.
