22inch Ek
kiid61
Re: 22's on ek-fb
Post by kiid61 »
Scubbs
Re: 22's on ek-fb
Post by Scubbs »
I see
With a split I guess you could have the front section of the hump at a reasonable height and the back section of it can taper up
and can be hidden by the seat and wont give as high hump most of the way through
kiid61
Re: 22's on ek-fb
Post by kiid61 »
Yep, its a perak Tim..
(AUST)Mod
Re: 22's on ek-fb
Post by (AUST)Mod »
I take back everything negative I said about your project - at least for the rear wheels - that looks 8) 8) 8) 8)
kiid61
Re: 22's on ek-fb
Post by kiid61 »
Cheers, Looks even better in the flesh....
Re: 22's on ek-fb
I agree with Scubbs, two piece tailshaft. Otherwise you'll have to have a monster tunnel. It wouldn't be too hard to add in a centre bearing mount as part of the chassis work you're adding.
Good to see you posting up pics, especially considering what has happened.
kiid61
Re: 22's on ek-fb
Post by kiid61 »
Thanks DR,
The tunnel wont be too huge. The floors going to be lifted to where those new rails are sitting if you can see.. But I'll definalty look into it when the time comes.....
May even be able to bring it to nats :wink:
J
Re: 22's on ek-fb
Post by J »
I like the current stance...
can pretty much guarantee I wont like it when its at full lift lookin like a donk.
Either way, I like the colour of the wires too. Werent u thinking black with fb flash the same colour as the spokes?
thatd look pretty dayum cool, maybe with a thin band whitewall cut into ur lowpros
Harko
Re: 22's on ek-fb
Post by Harko »
Couldnt help myself ...
This is too cool , Ill be watching your whole thread with enthusiasm :wink: 8) :)
kiid61
Re: 22's on ek-fb
Post by kiid61 »
I also wont like it lifted either.... Hence why i'm doing all I can to keep it low as possible ;)
Re: 22's on ek-fb
kiid61 wrote:I also wont like it lifted either.... Hence why i'm doing all I can to keep it low as possible ;)
Same... :shock: :lol: :lol: :lol: :lol:
Maybe go only as big as 18's on the front and it will reduce then need to lift it so much when driving?
kiid61
Re: 22's on ek-fb
Post by kiid61 »
It may look funny with 18's and 22's...... I'm looking at getting some 20's and having them chopped to make them 6.5" with decent fwd offset so I may not have to widen the front guards too much.... Tho if I was to pump the fronts and also the front doors a little it may look slightly cool. :twisted: :twisted:
J
Re: 22's on ek-fb
Post by J »
or 13inch wires with 520's on it 8) 8) 8) 8) 8) 8)
cmon dnt u wanna have the first EK/FB lowrider?
it would lay, hard...
kiid61
Re: 22's on ek-fb
Post by kiid61 »
It already will with anything less than 20's ;)
Re: 22's on ek-fb
Post by mrs ratbox »
without trying to argue :roll: but i can't possably see how that would lay rail looking at those pics even with smaller wheels unless you go down to about 15's and the diff goes higher
