hq disc
Grimbo
Just a couple of questions in regards to HQ stubs on HR front.
1. When using the HQ stubs on the HR front end do you use HR steering arms?
2. Also do you use the HQ calipers on factory intended sides L/H on left and R/H on right or do you have to swap them over for clearence.
I have heard/read that there are some fouling issues when using HQ stubs. I hope someone can clear this up as I'm about to convert my HR to HQ brakes.
Sam
Sam
fj_225
Re: hq disc
they sure do
FCOV6
Re: hq disc
Correct, all holdens use the same size bj's from the HD up to the WB as well as torana LC-LH.DOLLER wrote:So HR Ball joints are the same size as HQ??
DOLLER
Re: hq disc
I have HQ disc's, hq stubs, HQ calipers but have (again) changed my mind on rims and have got a set of 15 prostars off a crappadoor. Yes they fit but are not hub centric (?).
QUESTION
Can I put VN Disks on the HQ stubs and still use the HQ calipers so the crappadoor rims fit????????????????????
Shit i'm confusing myself now!
And after all that, are the 5ich back on these rims gunna cause me too much of a headache?????????? AHHHHHHH I really wanted to use these rims. Got them for a steal!
QUESTION
bat53retro
Re: hq disc
g,d
ay why not machine center hub on disc to suit the rim
cheers bat
cheers bat
DOLLER
Re: hq disc
Disc hub diameter is smaller than rim. Does that make it hub centric or stud centric?????????????????????????
bat53retro
Re: hq disc
g,day dont know what disc your running but hq - wb disc center hub is about 2 mm bigger than commodore
cheers bat
cheers bat
DOLLER
Re: hq disc
Geez my look to be the other way round???? I'll have another look when I get home.
Re: hq disc
I've got an HR front end with HQ stubs, HQ discs and what i think are WB calipers but im not 100% sure.. They stick out a fair way on the back side and foul on the tower of the crossmember when turned and ive lost quite a bit of lock because of it. Obviously i cant use these calipers so what are the right calipers to use?
If someone can tell for sure what calipers ive got thatd be cool too..
bat53retro
Re: hq disc
g,day brodie .
they are wb , i use hz , with slight modes to the cross member
cheers bat
cheers bat
- BILLY BLACKARROW
Re: hq disc
I have HR front end with HZ brakes with drop spindles and my caliper is to the back
BILLY
BILLY
BILLY BLACKARROW
Re: hq disc
Cheers Billy
Thanks bat, what did you do to the crossmember?
