Does anyone have any new crank bearings, crank thrust bearings and a maybe even a new crank ? Motor could be a 138. Engine number is B320XXX which I understand is FB/EK 138 ??
Mechanic checked motor yesterday and diagnosted too much crank float. Strange, since the motor has only done little work. They don't have time to remove engine so I had to do it myself. Lucky for sick days
Today I pulled out the engine. I supposed to be traveling from adelaide to NSW - leaving next friday 26th in this car.
Dropped engine off to engine builder this arvo. Hopefully the engine builder will be able to sort issue quickly but parts are likely to be a problmem
Plan B is a reco motor from HM GEM, Southcots @ $3200 exchange. Ouch. At least they have stock (australia wide apparently as they did a batch recently)
History.
Since recently installing fresh motor I had a strange clutch noise when pedal was pressed.
As usual I thought clutch thrust bearing or spigot bush - strange since thrust bearing was new.
Dropped past a clutch specialist and they had a quick listen. They thought it wasn't clutch thrust bearing. This was because noise didn't start when slack was taken up and when thrust bearing touched pressure plate. Noise started when clutch pedal was about 1/4 down, and then all the way to the floor. They thought if its not clutch thrust, then it must be spigot.
A 2nd, more serious, noise started a couple days ago. It was louder, sounded like it was coming from the dissy, internal oil pump area but I'm a bit deaf. Sounded bit like a whurring of gears.
This noise was there when it was idling, and revving - irrespective of gear position or clutch. I swapped dissy as a remote chance but no luck - problem still there
Off to the mechanic who couldn't find much apart from the crank problem. They think the clutch noise is related to crank problem. Movement is around 1 to 2 mm. Apparently should be just a few thou. Too much more and crank hits the block.
The only thing I can think that might have caused too much crank end float is me fitting the flywheel inspection plate, while gearbox and motor were in car. I needed to bang it in. Not sure if it was around the wrong way. Which way do they go anyway ? Bumps to the rear / outside ?
Apart from that I'm not sure what might cause the issue with a fresh motor.
At least the problem didn't happen half way across the hay plains !!
Hopefully better news tomorrow.
Peter.
