EK61's Supercharged V6
Cal
Re: EK61's norman supercharged grey
Post by Cal »
Still confused :? :mrgreen:
How does the fuel/air get to the manifold on the other side?
ek61
Post by ek61 »
yeh theres a bit more pipe work to go
the blower will suck the fuel through it and spit it out the other side blowing it through the pipe work
and into the manifold 8) 8)
***just cruise***
You want to keep that pipe as short as you possibly can Dave.
vintageholden
Post by vintageholden »
much better with the carby down low....
like you said..you wouldnt get away with it for to long...
Sputzwagon
Post by Sputzwagon »
I love this 'Aussie Engineering' going on here, Dave 8)
You'll have to video the thing when you get it going so us East Coast folk can hear the Norman at work. :wink: 8) 8) 8)
Scotty.
Woofto Car Club Member No 2
ratrod fj
Post by ratrod fj »
hi there
ek61 its grantley here
i used a meth aditive instead of castor oil as i have been told that castor oil will gum up the fuel and carbie
grantley
done any more ?
ratrod fj
Post by ratrod fj »
hi there
when in shed i wrote what was on the bottle
vp racing is the brand m2 scented
its scented candy smell so you know that you have got it in the fuel
upper lube and permormance additive for methanel fuel
made for superchargers
i bought it from bob fisher automotive
i hope this helps
grantley
:roll: :roll: :roll: :roll: :roll: :P :P :P :P :P
ek61
Post by ek61 »
its been a whie but heres a quick update :oops:
after all the headaches of tring to keep it under the hood with it mounted low on the other side of the engine
its not still not going to work
so ive had a play and after talking with a few people come up with a copy of an orig type manifold set up and will run a 2inch su
most of the work is done just a quick clean up and can start putting it all together :D
***just cruise***
ek61
Post by ek61 »
sorting the alloy plate to help take some of the weight
***just cruise***
ratrod fj
Post by ratrod fj »
Hi there
How is the project going ?
ratrod fj
More photos on blower ?
grantley
ek61
Post by ek61 »
yeh getting there just a few more bits
getting the su's checked out relocating top radiator hose and waiting on a cam
not too far away 8) 8)
hows yours going ?
cheers dave
***just cruise***
ratrod fj
Post by ratrod fj »
Hi there
mine great up and running
first i used the alt for the belt tentioner but the belt was coming loose
So i got a idler pulley made and took the alt to a belt drive of ham balancer and no problems
the motor is got to be dynoed the temp when driving on say 20 to 25 degrees day is 180 to 190
i think that the car is running to lean
i have a big thermo on it
i am doing another lc xu1 lima mnt in colour 70 model
i tell you the carbs are very noisey sucking sound when cruiusing down the road
Grantley
MeFB
Post by MeFB »
How's the Norman going Dave? Any tips?
I'll be doing a very similar install myself soon and would appreciate any advice.
Luckily the supercharger already comes with the carb mounted just how you've set it up in the last picture, so it will fit under the bonnet OK (carb is original to the supercharger kit). The casing on mine is a little different though, the cooling fins are radial and there isn't any water cooling. Lube is from a Marvel Mystery Oiler which is also part of the original kit.
I'll have to replace the bearings and seals and overhaul the carb. The kit has never been used, but has been sitting since before I was born so it will need a little love first.
I just have to work out what the heck to do to the rest of the engine. The greys are low comp anyway, and the blower only makes about 5psi with the 1:1 pulley so that will work, but the head could maybe benefit from bigger exhaust valves, and a cam of course. Some strong rods and a stud girdle to strengthen the main bearing caps would help.
I'll probably add water / methanol injection to the plenum.
Oh, forgot, lots of polished alloy and carnation red paint - that's the most important bit :lol:
:arrow: :D
Alan
ek61
Post by ek61 »
8) 8) wheres all the pics :lol:
ive been a bit slack had a lot of stuff going on latley but thats a diferent story :roll:
mines almost done ive changed the top manifold again to run twin su's it's getting welded now
so it wont be 2 far away ,just have to work out linkages /cable to the su's and pretty much there
the engine in the EK is gettin on in age now so im going to set it all up on this engine and sort out all the bits n bits
why i get the new motor sorted , im not going crazy with it just balanced ,cam and a bit of head work
after all its just a cruiser not a race car 8) 8)
then lots of polishing as well
cheers dave
***just cruise***
MeFB
Post by MeFB »
No pics for a couple of weeks yet, still in Batam at the moment :(
I'm pretty much on the same page as you with the build. I don't want to go screaming around the place at 100mph, I just want the challenge and satisfaction of getting it all to work :thumbsup:
:arrow: :D
Alan
