Removing front rubber brake lines
paperboy
State: ACT
Post by paperboy »
Can anyone help me on how do I remove the rubber front brake lines, it seems to be locked in with a large u shaped metal clip. I've got a broken hose and I'm replacing the brake cylinders.
Thank you in advance, I've bought a workshop manual but haven't received it yet.
Geoff
wot179
Re: Removing front rubber brake lines
Post by wot179 »
Yes, its a spring clip.
Grab the pokey out flat bit with a vice grip and pull down.
Wiggle it a bit as you go.
Be sure to undo the hardline first.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
paperboy
State: ACT
Post by paperboy »
Thanks, that was easy once I knew how it was suppose to come off.
wot179
Post by wot179 »
No wuckas.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
