FITTING BUCKET SEATS
ek wazza
Post by ek wazza »
In the process of deciding on bucket seats to fit and working out how to go about it. Does anyone have any pics of buckets seats in your car and how you mounted them??
Building an EK Special Sedan 304 T700, Rodtech F/end with disc's front & rear, and driving an EK Special Sedan Grey with Trimatic and the rest stock
gpi
Re: FITTING BUCKET SEATS
Post by gpi »
They can be a bit of a bugger to mount , owing to the shape of the floor - Gazza fitted Commodore seats into his black beast and did a good write up of how he made the mounts - have alook in the MY FB/EK section , I will bump the thread for you . Not sure what page its on but have a read through - there is TONS of good information through the entire thread.
I remember well when I fitted HX buckets to my sedan in the eighties (yuck, right?), I made up spacer brackets from some jarrah fence rail off cuts I found lying around, with long bolts from the local hardware. At least I used some half decent washers. That car never went over the pits obviously. Later came to my senses, welded up the holes and put the bench back in, with column auto.
Not very helpful I’m afraid.
Blacky wrote: Wed Jul 28, 2021 9:04 pm They can be a bit of a bugger to mount , owing to the shape of the floor - Gazza fitted Commodore seats into his black beast and did a good write up of how he made the mounts - have alook in the MY FB/EK section , I will bump the thread for you . Not sure what page its on but have a read through - there is TONS of good information through the entire thread.
Hi Blacky,
I have tried to find this info but cant find it. Can you point me in the right direction please?
b
Thanks Harv. I can't find any pics of the inside rails- which of course are where the floor is at its most uneven. Are there any ? Is Garry still about and contactable?- last post was in 2017😒
Hi Brett,
This is what I made up for Commodore seats, similar to Gary's.
Scroll down and open the picture in a new window to loose the photo bucket label.
viewtopic.php?f=11&t=882&start=240
Brett027 wrote: Mon Nov 29, 2021 12:17 pm Thanks Harv. I can't find any pics of the inside rails- which of course are where the floor is at its most uneven. Are there any ? Is Garry still about and contactable?- last post was in 2017😒
Only other picture he has is here, once the Dynamat went down:
viewtopic.php?f=11&t=3740&hilit=v8ek4us&start=570
Many thanks Gary- great ideas and amazing build too😀. Thanks Harv, Do you know if they were welded directly on to floor pan or bolted on like Gary's?
Greg ! My Names Greg !!!!! Ha Ha ha.
I'm pretty sure Gary has welded his mounts in, I (Greg) have made removable mounts just in case I ever decide to change the seats.
Thanks Garry😁.
Just kidding, sorry Greg🙂. Appreciate the help very much. I've sent a question about welding vs bolting to cert engineer. Will see what he says.
Bill
