master cylinder what kind
superstock
Post by superstock »
Need to find out which master cylinder to run, not sure HQ will have capacity. Have fitted volvo disc brake diff.HR frontend with volvo 4 spot calipers & discs. Have mazda 929, gemini, volvo, xb falcon master cylinders all hit hindge spring. any ideas many thanks.
FB ute obsessed $$$$$
Option 1) Move brake pedal and master cylinder to the left an inch or so or
Option 2) Remove spring and modify bonnet hinge , fit gas strut
Have a look here -
http://www.fbekholden.com/forum/viewtop ... c&start=15
I used a Hk booster with an off set bracket plus abit of grinding and drilling and welding :roll: , I now have no spring on that side but didn't have to modify the hinge, Trev 8) .
FB MAD
Post by FB MAD »
Trev wrote:I used a Hk booster with an off set bracket plus abit of grinding and drilling and welding :roll: , I now have no spring on that side but didn't have to modify the hinge, Trev 8) .
I am going the same/similar way that Trev has but have been toying with the idea of just repositioning the spring by modifying the bonnet hinge and fitting the spring or an alternative spring between the hinge and guard.Haven't even looked at this possibility yet but thats what I'm thinking of doing so as to still have spring assisted opening/closing.
FCOV6
Post by FCOV6 »
HQ will be fine if its a 1" bore, commodore cylinder/booster is also a good fit.
superstock
Thanks,Blacky,Trev,FBmad,FC0v6. My FB ute is all back together. Think I will look at HQ master cylinder if they are 25mm Come to far to move brake pedal box. many thanks all.
FCOV6
Post by FCOV6 »
superstock wrote:Thanks,Blacky,Trev,FBmad,FC0v6. My FB ute is all back together. Think I will look at HQ master cylinder if they are 25mm Come to far to move brake pedal box. many thanks all.
I have a new HQ m/cylinder with a alloy adapter i made to bolt in place of the original that i'm not using, all you need is a pair of allen head bolts and its ready to fit :wink: . Pm me for details/ price.
regards,
Nick.
superstock
HI nick yes I would be interested in mastercylinder. Can you email me for total price/postage to Collie W.A. 6225. Many thanks Wayne.Or can phone me no 0419966381.
FCOV6
Post by FCOV6 »
superstock wrote:HI nick yes I would be interested in mastercylinder. Can you email me for total price/postage to Collie W.A. 6225. Many thanks Wayne.Or can phone me no 0419966381.
I will email you some pics as well, i also have a VH40 and VH44 that i wont be using- clearing out all the stuff i dont need.
superstock
Thanks Nick I have already got vh 44/vh40 plus gemini boosters.
ben
Post by ben »
G'Day one other option is rx2/capella Booster/cylinder. Bit of grinding on the hinge and you loose one bolt, but apart from a few holes in the firewall it bolts straight up to existing pedal. I took this of my rally car which used to run volvo 4 pot fronts and single pot rear and stopped well. This setup on the FB runs HQ front discs and hr rear drums and also pulls up well
superstock
Hi ben that looks like a good fit. Looks very much the size of gemini booster? Would perfer to have setup like you have.There are so many options I didn,t know about.many thanks Wayne.
ben
Post by ben »
The booster is 7inch at widest point, so probably close to Gemini. Was camping at honeymoon pool last week and got some supplies in Collie, so could of dropped a spare booster to you. Anyway have one here if you get up to Perth anytime. The master cylinder is 7/8 (could be same as your 929 one if 70s) and running disc brake rears it does bias a little to the rear which is good on a rally car ( theres a few dirt roads around Collie :wink: ). Some circuit racers use the same booster with a 1inch early Nissan patrol master which bolts up. I think there is a write up in the hopper stoppers web site.
superstock
Thanks Ben, been in shed all day ,Gemini booster is also 7inch, bracket on back was 85 mm out from firewall to booster. So cut down to 25mm & welded. don,t even have to diegrind hole in firewall even original mounting holes line up. next up hindge. If I use volvo master cylinder has to be right , what do you think. many thanks Wayne.
ben
Post by ben »
For sure go the volvo master, as you said, it will all be balanced. Your probably already aware but If its a ATP 4 spot caliper with two lines and you don't use volvo master. You only run one line to the caliper (block of other feed hole) and you need to drill a 2-3mm hole between the two outer pots
Anyway sounds like the gemini booster fits up well, you will have to throw some pics of the car up for us
Ben
