SB Chev V8 engine mount when fitting to FB/EK
Posted: Fri Oct 16, 2009 1:17 pm
I don't ask too many questions here so it's my turn to ask for advice
I'm fitting 307 to EK.The 307 currently has no engine mounts.
When fitting small block chev to FB/EK using Castlemaine Rod Shop modified HR front end with front mount Torana rack.............................................................
............... Which is the best engine mount to use??....... and why??
I'm thinking HK/T/G
Don't have access to any of the different mounts to appraise and don't have the $$$ to buy every different type ever made to see which fits best so was hoping someone here already running a SBC in an FB/EK can advise as to which is best to get for the install to save my time and $$$.
One other thing, I intend to run T350 trans on the 307 with a column shift if that makes the choice of engine mount more clear.
Thanks for any help in advance
I'm thinking HK/T/G
