polishing stainless
Posted: Fri Jul 16, 2004 9:16 am
I have at present removed the entire grille from my EK whilst cleaning up the radiator baffle area.
I am considering dismantling and polishing the grille whilst I have it out.
Has anyone effectively done this?
I have a 8 inch bench grinder and will pick up both calico and fine buffs for the job - together with the compound bar for stainless.
My question is - has anyone gone through this process, is it worth the effort - I suppose to the fanatical perfectionist any result is worth it, but to the general (no pun intended) observer, is a day or so spent hunched over the workshop bench justified?
I am led to believe stainless will polish up to nearly a chrome finish if done correctly. I managed to polish my interior door trim bars to almost that using a dremel and quite a few different compounds of metal polishes but I suppose the initial supply of interior stainless may have been polished to a much higher standard than the grille bars?
So, my fraternal enthusiasts - who can glean some experiential knowledge in my (and for the general betterment of our genre's ) direction?
anxiously waiting reply,
