stuff on inside of roof
Posted: Thu Aug 27, 2009 11:11 pm
by mrs ratbox
on the inside of the roof there's a tary cardboardy type stuff is this just an insulator it's not there anymore on mine 1. do i really need it 2. what is something i can use instead
Posted: Fri Aug 28, 2009 9:27 am
It is there to stop the roof drumming Ratbox, I wouldn't remove it but if its buggered I dont know what to replace it with - no doubt Dynamat would have a product available but it wouldn't be cheap.
Posted: Fri Aug 28, 2009 9:47 am
by mrs ratbox
don't have a choice it's already gone :shock:
roof sheeting
Posted: Fri Aug 28, 2009 2:42 pm
by ek wazza
you can buy sound deadener sheets from panelshop supply companies that you can cut out and stick on whatever shape you like. they are used alot for newer vehicles on boot floors and spare wheel wells.
Posted: Fri Aug 28, 2009 11:30 pm
by Finny
I had a small section missing.
I reattached the areas that had dropped down using contact adhesive.
But I also had a small section missing.
I thought I would grab some from the parts car to re-use.
Unfortunately it was badly eroded and fell apart as I removed it.
Then going to use some from a parts commodore roof.
It had similar insulation to floor insulation.
But it had already been taken. This is what it should have looked like.
Probably end up using dynamat.
Posted: Sat Aug 29, 2009 1:29 am
Theres a bloke at the hotrod show selling dynamat - 36 square feet - about enough for a roof and a bit - $275 :shock: and thats a show special price , normally $325 :shock: :shock: :shock:
Posted: Sat Aug 29, 2009 10:28 pm
by FB MAD
:roll: Sheet :roll: , think I'll pull a few pink batts outta the roof of my house and glue them in !! :lol: :lol: :lol:
Posted: Sun Aug 30, 2009 9:27 pm
by blue ute
Be a bit carefull as there is only a small gap between the bow centre & the roof line (almost on the roof), remembering the original insulation was only approx 3mm thick.
Posted: Tue Sep 01, 2009 7:16 pm
by fb cruzn
A guy i knew used the silver and blue stuff thats used on houses, sizealation (spelt wrong) is what its called i think, if its not used at all the condensation would wet and stain the roof lining
Posted: Fri Sep 04, 2009 7:00 pm
by EK DAZ
I pulled mine out of my wagon because there was quite a bit of surface rust between the roof and the cardboard type stuff.Also because the cardboard stuff went above the steel hood bows, I ended up drilling the spot welds out of the two hoodbows on one side so I could get above them.I will have to tack weld these back in later.
