Angle Grinder ? Part of car gone. Problem !
Posted: Tue Aug 04, 2009 8:37 pm
by Finny
The angle grinder did a good job of cutting out rusted areas. :D
Welding did a good job welding metal back in. :D
Most areas where just a matter of leveling back to the surrounding areas.
The front corners however are a bit more challenging.
I didn't have a combined solid piece to use as a template.
Using Fiberglass as filler (Don't want rust again).
Now I have the issue of getting the shape right again. :? :?
Does anyone have any close up photos of the front corner ?
Door open, door closed, different angles ? :? :?
I have the grill section. So under it will be OK.
But I thought there was a bit of metal showing above the door when it is closed.
This is what I have at the moment, same on both sides.
Posted: Wed Aug 05, 2009 7:30 pm
by matchew
i dont quite get what ur saying but im pretty sure the windscreen covers most of the area high lighted
sorry if this doesnt help :oops:
Posted: Thu Aug 06, 2009 12:18 am
by Finny
Thanks but I;m just after some pictures of that area.
I believe that part of it shows and I want to try any get the angles right.
If I get the covered ones wrong then the bits won;t sit down when I start putting it back together. :shock: :shock: :evil: :evil:
Posted: Thu Aug 06, 2009 8:22 am
by parisian62
Finny I can get you some pics but it wont be till this this arvo.
Stewart
Posted: Thu Aug 06, 2009 4:27 pm
by Finny
Thanks Stewart.
:D :D :D
Posted: Thu Aug 06, 2009 9:04 pm
by matches
i got a pic of mine for you, its still original never been repaired.
hope this pic shows what your after, if not let me know and i can take more angles for you as that whole section of the car only has panels sitting in place.
Luke
Posted: Thu Aug 06, 2009 10:07 pm
by Finny
Thanks Luke, that's a great shot. :D :D
Really helps to see the lines.
Just need someone to do one exactly the same but with the windscreen and guard in place.
Posted: Thu Aug 06, 2009 10:37 pm
by matches
not sure if these shots help but they do show before windscreen came out.
Posted: Fri Aug 14, 2009 9:21 am
by Finny
matches wrote:i got a pic of mine for you, its still original never been repaired.
Luke
Thanks Luke, pictures have been very helpful.
Just doing the final adjustments.
Can you can get a couple more photo's of the corner areas, and the bit at the front where it drops down under the grill (Air vent) plate ?
Posted: Sat Aug 15, 2009 4:37 pm
by careyman
looks like the same area i got to get done too :roll:
Posted: Sat Aug 15, 2009 9:33 pm
by Finny
Thanks guys. :D
Careyman yours looks very similar to mine originally.
Mine was probably a little worse.
Have now finished the corners.
Posted pics on my wagon topic. :D :D
