Anybody help me how to prime fuel system? Engine has been out of car for quite a few months. I have fuel to inlet of pump but can't get it any further. Carby was drained also.
Do I keep winding over till flat battery?
cheers
Both those work, but pouring a bit of fuel down the carby always works..................especially when you run out of fuel and the fuel system is bone dry
Thanks for the tips - had forgotton about the hand over carb trick.
Also helps to wire up the coil correctly.
Had it running tonight; rough but it idles!
Patrick
