Fuel Pump
Cal
Fuel Pump
Post by Cal »
Hey all 8)
My fuel pump seems to have sprung another leak :roll:
This time it's actually spitting out fuel rather than a drip. straight onto the engine . It seems to be coming from where the pump meets the engine block, though I thought no fuel actually went down that far in the pump....
The gasket there looks rooted. In actual fact it seems like someone has stuck silastic all around there.
Is it just a simple case of undoing the 2 bolts, taking out the pump and putting it back on (with a new gasket) ?
Be pre warned, you're talking to someone useless here 8)
Sounds like it's stuffed, if there is a swap meet on and you have a spare $5 go and get another one, or someone on here that is up your way should have a spare, Trev 8) .
Cal
Post by Cal »
Spare 5 bucks?? :D
I just spent 100 on a new pump..........now for the hard bit.
Taking out the old one and putting the new one in :oops:
On taking a closer look it looks like the diaphram was stuffed.........changing that is beyond my limited capabilities 8)
Cal
Post by Cal »
Well, thanks to a new pump and some over the phone guidance from Terry (FB MAD), I'm back on the road.
Much appreciated, Terry. If it weren't for you I'd still be standing there scratching my head :oops: 8)
Post by mrs ratbox »
i've had the fuel system bug this week aswell :roll: :roll: :roll: :x nearly bought a pump i didn't need :shock: :? running great now but has a blown head gasket :roll: i'll fix that monday before i go home, it never ends :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :( :? :D :lol:
Cal
Post by Cal »
How did you blow a head gasket? :?
Craig
Post by Craig »
Cal wrote:How did you blow a head gasket? :?
First you get down on your knees then..........
Better dead than red
EK, the VN of the 60s
just one of those things :roll: :( not even real sure of the condition of the rest of the engine :? a couple of times it fumed REAL bad but sat easily on 110kmh good laugh though a car that looks like mine billowing smoke at 145kmh (by the tom tom) beside one of those flash mitsubishi somethingorothers the guy's face was priceless something like this :shock: :? :shock: :? :shock: :? :shock: :? :shock: :? :shock: :shock:
:lol: :lol: :lol:
FBeing
Post by FBeing »
Hey guys it seems the fuel bug has caught me out too,
When the car's running it's actually sucking in air through the bottom of the glass (and leaking out there too)
I am presuming it's just an o-ring (rubber or cork??)
Can I just make an o-ring (or pick one up from an auto-shop) or should I buy a whole new diaphragm kit and give it an overhaul?
I found a kit (Goss) for only 15 bucks but postage is 15 as well, so 30 bucks an o-ring is a tad steep
Stu
Cal
Post by Cal »
FBeing, you can buy just that gasket for around 5 bucks.
if you buy it on it's own it comes in rubber. If you buy the whole kit you get a cork one.
You gotta be precise with a certain spares shop. Kit advertised for 20 bucks......you turn up and its 45 bucks.
For 99 bucks you get a whole new pump :roll:
FBeing
Post by FBeing »
Yep I reckon my pump is still OK so I will just get a cork gasket (or make one) from Supercheap on the weekend, certainly the cheapest and easiest option (thanks Terry!)
Stu
