Taking Front crossmember off
Posted: Sun Jan 25, 2009 10:50 am
by TimR
Having trouble getting the pitman arm off the pitman shaft at the bottom of the steering box.
Tried hitting it, a gear puller and lifting the car up to get weight off but its not moving.
Should we just disconnect the steering somewhere else then try to get it off?
Is it meant to be difficult to remove?
Thanks
Posted: Mon Jan 26, 2009 8:32 am
mighta been there nearly 50 years, try soaking it with WD-40 and get hold of a pitman arm puller , use the puller and give it a sharp hit when the puller is tightened up.
Posted: Mon Jan 26, 2009 11:33 am
by FB MAD
The correct method is to use a pitman arm puller or similar puller that will fit but sometimes they alone won't remove the arms and a little extra help is sometimes needed.
If you've got oxy-acetylene gear you can heat up the pitman arm and knock it off the spline from inside the engine bay using a steel pipe/bar whatever and a large hammer from above.
Sound a bit primitive but thats how a lot of older mechanics did it years ago.
That's how I've always done stubborn pitman arms over the years.
99% of the time the heat will stuff the oil seal in the bottom of the box but after nearly 50 years of use the oil seal will be buggered anyway.
I've fiited an aftermarket new oil seal I got at local bearing place for $7 and it works perfectly.Have the number for it if you need it.
Posted: Mon Jan 26, 2009 11:17 pm
by Finny
TimR, I had the same experience recently.
Couldn't budge it no matter how much force I used.
Take the puller off. If both wheels are in the air, grab the wheel on the opposite side and turn it from side to side. Mine just fell off. Or try it again after moving it.
Posted: Wed Jan 28, 2009 10:39 am
by TimR
Got it off using pitman arm puller and a few hits as well as moving the wheels side to side.
Thanks a lot!
Next up is taking the front off for repairs and then painted, finished and ticked off the list.
