Page 1 of 3
lowered
Posted: Wed Dec 10, 2008 9:57 pm
by Aussy Edo
Hi All,
i am chasin some info on how to drop my EK by about 2 inches,any info would be appreciated,its currently at the stock height i think.i wouldnt mind chasin up some 15 inch rims as well
EDO 8)
Posted: Wed Dec 10, 2008 10:07 pm
by FB MAD
Most blokes go the heavy duty lowered spring way for the front and lowering blocks or reset springs at the rear.
Are you talking of lowering a kingpin front or HR front end??
If you are running a HR front end you can go for lowered stub axles which is the best and safest way to go if you can afford the cost of the initial outlay for the lowered stub axles.
Can't answer the 15 inch rim question but I'm sure someone will help out with that one.
Posted: Thu Dec 11, 2008 8:22 am
by DNA
i think unless you get volvo rims you wont get 15's on the EK stubs......
change to HQ stubs and you have a heap of different rims available and can be dropped even more.
Posted: Thu Dec 11, 2008 1:16 pm
by Devilrod
Volvo's are the way to go, but I'd get rims first then lower the car. It'll highlight any potential clearance issues. And as the others have said for lowering, buy springs and blocks or reset the rear springs instead of blocks.
Posted: Thu Dec 11, 2008 9:17 pm
by karsten
i used kings springs
Posted: Thu Dec 11, 2008 9:59 pm
by basic.green
Hi i am thinking of buying lowered front springs (HR front) 2 inches but it might not be low enough. has any one done this and cut the springs to get it down a little more. how much do i cut 1/2 or one coil :twisted:
Posted: Thu Dec 11, 2008 10:15 pm
by Trev
I used Pedders heavy duty lowered front springs and cut 1 coil off, if I had lower profile tyres (not 75's) I would cut 1.5 off, Trev 8) .
Posted: Thu Dec 11, 2008 10:29 pm
by basic.green
Thanks Trev 8) i will have 15x165 65 on the front 4inch rims so 1 coil sounds the go
Posted: Thu Dec 11, 2008 10:34 pm
by Trev
Mine are 195/75/14's
Posted: Fri Dec 12, 2008 12:15 pm
by FB MAD
If you are buying heavy duty lowered springs and want to lower it further I would take a half cut first and see how it goes.I know its time consuming taking smaller cuts and fitting/checking but if you take off too much,you can't put it back on,you'll have to get another set of springs and start again, as I had to do on a car years and years ago when I cut too much off a brand new set of lowered springs in my HQ Monaro :oops: :oops: :oops: .
Don't cut with oxy/acetylene either,cut with an angle grinder.
Oxy/acetylene and excess heat can cause embrittlement in the area of the cut and the spring can break or bend in that area over time.
There again,if you buy the exact brand springs and rim/tyre combo that Trev has and follow Trevs advice with that combo then I 'spose that saves some time with following the procedure I described.
Posted: Fri Dec 12, 2008 2:26 pm
by Trev
What I found with the heavy duty spring is the car only dropped the same amount as what was cut off, in my case about 1.5 inches, Trev 8) .
Posted: Fri Dec 12, 2008 9:04 pm
by Aussy Edo
Thanks for the heads up boys,
i forgot to say it is a king pin front end,so lowered springs are the way to go.is there a year range for the volvo rims to fit the ek, for eg 1980-1990 models or any thing like that i need to worry about,there is a volvo wreckers on my way home from work i might sus out.Karsten,you reckon king springs are the way to go mate?,had any dramas?.i will get the rwc for the ek before i go messin around but atleast ime headin in the right direction thanx again people. 8)
Posted: Fri Dec 12, 2008 9:44 pm
by karsten
yeah mate i got em and i wouldnt say it couldnt go lower but i like the hight and it dont ride like a pig,,, i havent ridden in trevs so his advice i cant comment on ,,,,,, but whatever trev reckons would be right mate so i guess its somthing you want to think how you like the hight side to be ,,, but there in my drum front and it does inprove the dynamics of body roll and looking at the sky,,, my ute is lots lower and it has hr front ,, and it rides very nice as good as the sedan ,, and low does look trick,, depends on the rim size to
Posted: Sat Dec 13, 2008 7:07 am
by FB MAD
I'm running kingpin front end and fitted a pair of old Selby heavy duty lowered springs that Brown Bear gave me.
I cut an additional full coil off the end as well.
It lowered it 3 inches from standard but the suspension was then riding on the bump rubbers so I then had to shorten the bump rubbers and try and shape them in the original cone shape to maintain some progressive bump.Gained about an inch of suspension travel by shortening the bump rubbers.
In hindsight I wish I'd only cut half an additional coil and gained some additional suspension travel as its fine on smooth roads but shakes the shit out of the car when you hit a pothole.
Ride height looks good though even with the piddly standard 13 inch wheels I'm using ATM.
Posted: Sat Dec 13, 2008 7:30 am
by Trev
FB MAD wrote:I'm running kingpin front end and fitted a pair of old Selby heavy duty lowered springs that Brown Bear gave me.
Terry, I recon the ride height on yours looks perfect, I wouldn't change a thing (even the wheels)!
Hows the old piece of shit (as your son calls it :lol: ) going anyway? Trev 8) .
