STEERING COLUMN FOR R&P ?
Posted: Wed Dec 03, 2008 3:39 pm
by FCOV6
I originally many moons ago cut down a HR column for my CRS R&P conversion but i read somewhere that regs have changed and you now need a collapsable column to pass engineering in Vic ? is this true or will a different column suffice ?
Posted: Wed Dec 03, 2008 4:42 pm
by FB MAD
The Victorian boys might be in a better position to answer this than me or ring Vicroads or Vicroads approved engineer but..................
In NSW anything over 186 red needs to have a collapsible steering column and there is information on this requirement under National Code of Practice for Light Vehicle Modifications via the "Dotars" site.
All states follow this standard but they do 'tweak" the rules to suit their own requirements so there can be some differentuation between each state as to rule interpretation.
Posted: Wed Dec 03, 2008 4:50 pm
by FB MAD
Go to "General Sharing Advice and Experience" section on this forum and click on the sticky thingo at the top called "Very Handy Site".
You should be able to find the info you need there.
If its any help I'm doing 307/T350 to EK and I'm planning on using a HK Auto collapsible column in mine.
I know of other blokes that have used Torana,HQ/WB,Commondoor collapsible columns as well.
Posted: Wed Dec 03, 2008 4:57 pm
by FCOV6
Cool thanks, thinking a HK-HG column might work out the best.
Posted: Thu Dec 04, 2008 7:20 am
by Mephious
I used an LH-LX column in the EK sedan which mates to a CRS front mount rack n pinion.
The missus EJ also uses an LH column.
Posted: Thu Dec 04, 2008 12:11 pm
by FCOV6
Mephious wrote:I used an LH-LX column in the EK sedan which mates to a CRS front mount rack n pinion.
Does the lh column have plastic or metal covers ?
Posted: Thu Dec 04, 2008 1:05 pm
by Sammy
the lower section of the column is all metal ... but the top section has plastic like around the blinkers etc.
Posted: Fri Dec 05, 2008 7:51 am
by Mephious
The torrie column I used has a metal surround at the very top ( closest to the wheel) where the key lock assembly and blinker stalk resides. Below the metal surround is a large plastic shroud which mates the metal surround to the dash of the Torana.
I removed the blinker stalk, plastic shroud and ground down the iginition lock shape, removed all metal bolt anchors and cable clips.
A new polished shroud was then thrown over the top to clean it up.
Also picked up a column that wasnt column shift.
Heres the best picture I could find , sorry its somewhat old as the blinker wasnt fitted at the time of the shot -
Posted: Fri Dec 05, 2008 10:49 am
by FCOV6
Mephious wrote:The torrie column I used has a metal surround at the very top ( closest to the wheel) where the key lock assembly and blinker stalk resides. Below the metal surround is a large plastic shroud which mates the metal surround to the dash of the Torana.
Thanks, i didnt want an ignition switch on the column so one that is easily removed is ideal and an LH column will work well with the LH steering rack.
