fitting vr wagon diff, is it worth it? whats involved?
hi guys, i have access to a vr wagon for any parts except the engine if i want it. is it hard to fit up the diff? would it need shortening? can i use the front brakes and/or steering rack? any help will be much appreciated.
L&K
L&K
- Sammy
- Contact:
yeah what he said
have a look at page 9 here http://www.fbekholden.com/forum/viewtop ... &start=120
i dunno how much your willing to take on by yourself but i guess if theres someone local that can shorten it for you then would should be right .... i wont say its an easy job but its worth it for the strength you will get from the commodore diff and especially if you want rear discs and commodore stud pattern its the logical solution.
as for the steering racks, i have a non-power assisted one in my FB and i have heard the power assisted ones arn't real good, but having said that i have moved my car around with motor and all that in the yard and its by no means hard to turn so im expecting the steering to be very good!
Regards,
Sammy.
http://www.oldholdens.com
Sammy.
- Sammy
- Contact:
oh yeah front brakes ... if you have adaptors or hr drum brake stub axles then you can fairly easily put the VR calipers on the front of the EK .... you will need to get VP V8 front discs and then then the caliper is the same as a VP V8 ... also same as vl turbo and i think possibly VL V8 and vn v8 but im not 100% sure on the last ones ...
i have put these on my Torana with the drum brake adaptors..... i drive it every day approx 120kms and they work great!
Regards,
Sammy.
Sammy.
sammy, i currently have hr drum front. i rang crs and he said all i have to do is send the stubs down and he'll machine them and send them back with the adapters for $368, i think this is how i'll go. as for the diff, i'll have to get someone to do it for me as i have no idea and i don't have the confidence to try it out. any ideas on $$$ to have one done?
L&K
L&K
- Sammy
- Contact:
FAARRRRRKKK man i bought the adaptors from v6 conversions for like $150 i think and the machining i did with a file and grinder!!!
ahh the original diff i got done was $300 but that was a dodgy job (part of the reason i did the one in that other thread) so i would think getting one done wouldn't be much more than $400-500 ... but also if you can cut all the commodore mounts off and get it as ready as possible the places will have less to do ....
Regards,
Sammy.
Sammy.
i recently bought a vn lsd diff for the wagon which im not actually going to use now as i have finally found a wheel manufacturer that makes wheels to fit early stud pattern anyway i got priced about $900 to shorten the diff and axles to suit fb.and im not telling who makes the wheels till i have them for myself first yes im selfish and there not to dear either about $300 a wheel
yeprat are they 17" if so i was going to sujest them they may even find there way onto the car i'm doing now somewhere way in the future
matches, a mate of mine lives up there he used to do diff conversions basically for a living, i'll try find his number, he built and used to own the DOG 308 EK ute drag car
