The Red Report
Posted: Wed Dec 07, 2005 11:05 am
I finally got a mechanics report back yesterday from the red EK from Koo Wee Rup I checked out a couple of weeks ago.
I've asked for some clarification as I am a Web Developer not a mechanic ("mechanical dunce" is probably more realistic). It's very brief too:
Make Holden Rego TLC 354
Model EK Odometer 20868
Job Description Vehicle Inspection Report
Diff Oil Leak
Trans Oil Leak
Rear Universal Joint
Rust Left Hand Front Chassis
Left Hand Rear Door - Dose not open from inside
Seat Belt Bolts
Rust Rear Under Boot Line
The above items are Road Worthy requirements
Grease Top Left Hand Upper Control Arm – Outer Pivot
Grease Top Right Hand Lower Control Arm – Outer Pivot
Engine Power Test showed no major faults in engine other than
A major tune up
Vehicle considered being in very good condition for its age.
Would not recommended the vehicle be modified?
I am assuming that the last three points only are the ones about which I need to be concerned because the RWC will cover the first list as stated.
Can anyone offer me any pointers/suggestions? My next step is organising the RWC with the owner.
Paul
Diff Oil Leak
Trans Oil Leak
Seat Belt Bolts
A major tune up
Paul
