Moderators: reidy , Blacky
(AUST)Mod
Posts: 2272 Joined: Sun May 07, 2006 11:16 pm
Post
by (AUST)Mod » Thu Sep 18, 2008 4:02 pm
I bought some billet dash knobs. How do you remove the factory ones? Anyone looking for a good set?
Andrew
Craig wrote: Andrew you have a red so I wouldn't race it
rudigar
Posts: 45 Joined: Fri Aug 15, 2008 3:27 pm
Post
by rudigar » Thu Sep 18, 2008 6:35 pm
gday mate, for some reason theyre all different. window wipers have a grub screw on the knob so if you take that off then you can take of the silver plate at the front which just unscrews. For the choke just remove the actual choke cable from your carbie then unscrew, light switch if you pull it out so the lights would be on, then reach behind on to the part where the wires connect (probably best to undo the battery first) there is a liitle button on the top, hold it down then pull the knob and out it comes, then again unscrew silver plate, and im still working on my ignition switch but there is a post in electrical i think. This would be a lot easier if they were all the bloody same
Post
by Devilrod » Thu Sep 18, 2008 7:57 pm
What Rudigar said. For the ignition switch try a set of c clip pliers or carefully and patiently tap around with a screw driver.
(AUST)Mod
Post
by (AUST)Mod » Thu Sep 18, 2008 8:05 pm
Oh I mean just the plastic sections. I have unscrewed the wiper knob and put on my new aluminium knob, but how do I get the others off? Pull them?
Post
by Devilrod » Thu Sep 18, 2008 8:41 pm
Testing my memory but I tink you're right. I don't think they were really usable once I got them off. But they should pull off.
mattymartin
Posts: 841 Joined: Fri Oct 06, 2006 12:49 pm
Post
by mattymartin » Fri Sep 19, 2008 4:54 am
hey andrew,
sorry i cant help as my panel beter took mine off... (& cracked them)
so if you get yours off wothiut cracking/breaking them, i would dfinatley be interested in your old ones...
good luck
matty martin
go the wagons....
(AUST)Mod
Post
by (AUST)Mod » Fri Sep 19, 2008 10:06 am
I have the light one and wiper one off in good nick, they are yours. the choke I have mauled abit so I will prob pass on giving you that one.
