5 speed with bench seat
Malcolm
Post by Malcolm »
Hey guys,
Can anyone tell me if you can fit a 5 speed to a FB/EK with an original bench seat.
If so what 5 speed fits.
Malcolm W.
Post by mrs ratbox »
i had an alfa 5 speed in my flat blue sedan and that came up well infront of the seat
i looked at an FE with a celica box that came up just infront of the seat but my wagon has to have a cut out, but i'm pretty sure with the celica box there is shift position variations
Malcolm
Post by Malcolm »
Thanks RB. :wink:
Malcolm W.
camstuart52
State: TAS
Post by camstuart52 »
I had an FB Ute with a Celica 5 speed. The bench had a slight cut out, but a straight gear stick, if you went a bent gear stick with the original bench seat, it would clear from memory!!!
It was great to drive also!!!
macca4551
Post by macca4551 »
Hey Mal
Toyota steel case 5 speed with a CRS modified gear lever works a treat
Kind regards, Steve
EKISOK. So much work, So little time !!!!!
Malcolm
Post by Malcolm »
Thanks guys
cheers
Malcolm W.
FATBOY
Post by FATBOY »
im doing this conversion in my ute as we speak ive got a eh bench seat and it looks like ive got to make a custom lever to clear the seat
regards fatboy
Malcolm
Post by Malcolm »
Hey Fatboy,
I couldn't imagine there would be much difference in shape from an EH seat to an FB seat. How much do you have to change the shape of the shift.
A picky of the finished article would be good if you can when its done.
Malcolm W.
FATBOY
Post by FATBOY »
ill document everything and take pics .Ek seat front goes straight down eh has a slight slope at the bottom the s in the shifter will probably be around the 60 to 80 mm mark.Main concern if the seat is moved forward then the shifter will bind so will do a template tomorrow and get some rod bent and try it out tomorrow night when i get home from work
regards fatboy
FATBOY
Post by FATBOY »
Had to cut seat will take some pics tonight before i give it to the upholsters tomorrow
regards fatboy
FATBOY
Post by FATBOY »
Charging camera now to take pics tomorrow of how i cut it up In the centre of the bench i cut out roughly 160mm back into the seat and 160mm wide so when the seat is pushed forward it still works perfectly
regards fat
dave68
4 speed
Post by dave68 »
Have m20 had bench in, this is the shifter.
Image[/url]
Whatever....:(
yeprat1
Post by yeprat1 »
so what was the verdict guys cause i really dont want to cut my seat and i havent put my celica box in yet if it cant be done i may have to go auto instead
