HT/G 14" wheels to EK
Posted: Mon May 05, 2008 5:32 pm
by paroharo
This is hopefully an easy answer as it seems a lot of people have done it...
Do HT/G 14" steelies fit on the standard EK with no rubbing, fouling of guards etc?
What would be the widest you could fit under them ie. 6, 7, 8 inch?
Would there be any problems when the car is eventually swapped to an HR front end?
Jon
Posted: Mon May 05, 2008 7:26 pm
by mrs ratbox
the wagon i have has a 14" standard HT/G wheel on it no problems, i'm pretty sure standard HK wheels fowl the king pins, and i think the standard HT/G wheels are a problem with the HR front but not 100% sure
Posted: Mon May 05, 2008 8:09 pm
by oldnek
Rat, Your right on the money.
Posted: Tue May 06, 2008 8:18 pm
by paroharo
I reckon I'll get a full set of HT/G 14 inchers then as I'm still running the kingpin front end.
When I do eventually change to HR front, is there a way of getting around the clearance issues with the 14 inchers? - or do you just have to choose different wheels?
Posted: Wed May 21, 2008 8:45 pm
by jake08
I just fitted some 14 x 5 HT rims today with 195 tyres, i have about 2 mm clearance from the standard kingpin- Im not 100% but the negative offset seems to be bigger on the HT rims then the original 13s. If I drop my tyre pressure it looks like I might run into trouble.
Posted: Thu May 22, 2008 5:04 am
by Trev
paroharo wrote:I reckon I'll get a full set of HT/G 14 inchers then as I'm still running the kingpin front end.
I run the same rims, just get the offset changed, if you dont know how much just tell the wheel place thier for a HR disc front, they should know what thier doing.
I have 5" front and 6" rear, but I think you could go 7" rear with no probs, I have a mate with 8" rears and they are a real snug fit, Trev 8) .
Posted: Tue May 19, 2009 10:47 am
by Nekro63
Just wanted to bring this back up rather than start a new thread...
Have an EK ute, HR disc front and rear.
Have been told HK will not fit, you gotta have the offset changed (?).
Have been told (by holdent in clayton) that HT/HG 14x5's will fit.
All this true?
Posted: Tue May 19, 2009 12:41 pm
by Devilrod
Luke the HK rims run more negative offset (to the inside) so they will foul on tierods.
I've got a HR front but Torana Discs/calipers so the HT rims clear. Follow Trev's advice get the offset changed slightly and you should be right.
Posted: Tue May 19, 2009 12:48 pm
by thropzed
I run HT steelies on both my cars, The sedan is stock running gear and has no issues, The Wagoon runs Hr front with HT Monaro Rotors and calipers and has no issues with hitting anything, But I had to change my 195/75/14's to 185/60/14's so I could clear the front guards, Now I have no scrubbing issues. OH and its lowered 3 inches all round!
Cheers Theo Z.....................
Posted: Tue May 19, 2009 8:32 pm
by Finny
Does anyone have any pictures showing where different wheels are actually fouling ? and the ones that don't quite foul ?
Posted: Wed May 20, 2009 4:51 am
by Harko
I had HK front HT G rear on the wagon , no rubs anywhere .
Did use a small headed ball joint for clearence though .
