Moderators: reidy , Blacky
southcoastkustom
Posts: 537 Joined: Tue Nov 28, 2006 11:20 pm
Post
by southcoastkustom » Mon Apr 07, 2008 10:49 pm
Hi guys, am trying to post an avatar using the directions I have found on here, but keep getting the message "The URL of the remote avatar is not valid" I have resized the image, etc and noe its giving me the F#@*&%G SH*#TS!! Can some IT guru pls help....? Should I be using the IMG code on photobucket, as when posting a pic on here??
SCK
not too shiny thankyou.
Post
by Trev » Tue Apr 08, 2008 5:12 am
Looks fine to me
EKSPCL
Posts: 794 Joined: Sat Mar 15, 2008 11:36 pm
Post
by EKSPCL » Tue Apr 08, 2008 6:08 am
I had the same problem and the same words came out of my mouth
I think it turned out that you use one of the other links, not the IMAGE Code, but I can't remember which one
But it looks like it worked to me..........
My 6yr old daughter said
mattymartin
Posts: 841 Joined: Fri Oct 06, 2006 12:49 pm
Post
by mattymartin » Tue Apr 08, 2008 6:34 am
hey SCK,
looks ok, but if you wanted to be picky... the reason it looks not so perfect is that it need to be resized first... I THINK....
hope this helps
matty martin
go the wagons....
MINT62
Posts: 840 Joined: Sat Aug 05, 2006 8:52 am
Post
by MINT62 » Tue Apr 08, 2008 12:54 pm
gday SCK
you need to use the "direct link" for your avatar, not the "IMG code" - this is the one you use for posting up pics
only just recently updated mine
good luck with it mate
ray
INVEST IN PRECIOUS METAL
Posts: 3997 Joined: Wed May 11, 2005 2:19 pm
Post
by parisian62 » Tue Apr 08, 2008 2:11 pm
Hi SCK,
It's been a while since I wrote the Avatar instructions...see here
http://www.fbekholden.com/forum/viewtop ... =6075#6075
I've done some updates with the suggestions from Ray and EKSPCL. I hope its now clearer...we don't want avatar anger...
Anyone with suggestions on how to make the instructions clearer let me know...
regards
Stewart
southcoastkustom
Post
by southcoastkustom » Tue Apr 08, 2008 9:57 pm
Many thanks to all for the help...seems not using IMG code in photobucket has worked a treat!!
Thanks again...
SCK
