Fly Wheel
Posted: Thu Mar 06, 2008 6:46 pm
by strogger
Just a quick one,
Is the Grey motor flywheel interchangable between manual and auto ??
Thanks....
Posted: Fri Mar 07, 2008 9:57 am
by FB MAD
Ummmmm....... I guess you mean ??
Can I put a manual flywheel on to an engine that previously had an auto trans? Yes/No??
If Yes, the answer is Yes you can put a manual flywheel on a previously auto powered car and Vice-Versa also.
The grey manual flywheel is part number 7409867 ( from engine number 283372 ) and grey highlydramatic ( hydramatic
) flywheel is part number 7416749.
Not interchangeable ie:- Can't use a manual flywheel to bolt the Hydramatic Damper plate to it.Have to use the Hydramatic flywheel.And Vice-Versa also.
Hope this is the info you need,
Terry.
Posted: Fri Mar 07, 2008 1:49 pm
by oldnek
Straight Answer, NO.
