hr diff in fb wagon
bumper
State: TAS
hr diff in fb wagon
Post by bumper »
ive found out that once you put a hr handbrake cable in it is to short and have had to make up a piece to fit, has any one know a way to fix this problem propley??? cheers
Order one specificaly made for what you have done from here
http://www.autocables.com.au/
You tell him the car and what diff yoiu have and its done, from memory it was less than $100 delivered or was that the speedo cable :?
Either way his service and pricing is great.
Brown Bear
Post by Brown Bear »
I came across this problem some years back...
Rotten old cable in the wagon and nice clean one on a spare diff - easy swap, hey :D
Put it all in and pulled it up to the front brake arbor... well, nearly... about 6" too short! :shock:
Piece of flat bar with a hole drilled in either end and a second pivot/splitpin
solved it. 8)
On safari
bumper
State: TAS
Post by bumper »
the old flat bar with holes trick got the rwc!!! getting reg on thur
yeprat1
Post by yeprat1 »
im glad brought this topic up didnt know that
