Drum to Disc conversion
Posted: Thu Oct 25, 2007 10:54 pm
by farkamhall
hi all. my fb has hr front end but with drum brakes.can anyone tell me what i need to change this to disc brakes and the best place to get the parts.many thanks in advance
Posted: Thu Oct 25, 2007 11:36 pm
You could use HQ stub axles and brakes, but that will change your stud pattern - original HR disc rotors are still available if you want to go that way. HK-T-G will keep your stud pattern the same but you must run 14" rims. You could spend up big and go for a Hoppers Stoppers set up .
Theres lots of options.
Posted: Fri Oct 26, 2007 7:43 am
by mrs ratbox
you can get adapters but not really worth it when all you need is the stub axels and everything attached to them, once removed at the balljoints
you can get these from a variety of cars of coarse HD/HR 13",H/KTG 14",H/QJZX 14"different stud pattern, LC/LJ torana 13",LH/LX/UC torana 13"
with the later toranas and i think the H/ZX you may find wheel alignment difficult
i have used all of the above except adapters
Posted: Fri Oct 26, 2007 9:47 am
by farkamhall
many thanks guys
Posted: Sat Oct 27, 2007 12:05 pm
by FB1960
Hi
I am in the process of changing my front end from standard to disc.
Using a HR front cross member with HT stubs due to no stubs with the front end I got (for $60 for the cross member you can't complain) and torana discs(Cheaper to get parts for) to keep the early stud pattern.
You can purchase boosters new from Hoppers Stoppers or rebuilt from Hydroboost, I've been told you have to use the VH40 only.
Check out this guys link he does a conversion on his EH
http://members.ozemail.com.au/~mykell/garage.html
Posted: Sat Oct 27, 2007 12:12 pm
by farkamhall
many thanks marty
Posted: Wed Apr 15, 2009 8:23 pm
by FB1960
sorry for wrong information
but my info was incorrect, torana brakes will not fit HT stub but will fit onto standard HR stubs.
I've ended up using HT disc and torana calipers, allows you to go to 14 inch rims and keep the early stud pattern, you need the hat section for the discs as they are two piece.
hope this helps
Posted: Sun Feb 07, 2010 11:58 pm
by Finny
Marty, do you have any pics of your calipers ?
Posted: Mon Feb 08, 2010 9:29 pm
by FB1960
here ya go
Posted: Mon Feb 08, 2010 9:38 pm
by Finny
Thanks Marty, it fits will other images I have found today.
The PBR unit must be a Torana caliper, as it doesn't have the same shape as other HK, HT, HG calipers I have now seen. Unless the PBR units were an alternative to tghe Girlock units.
Thanks again
Posted: Mon Feb 08, 2010 9:54 pm
by FB1960
Yeah you are right Finny, it is the Torana ones as we had some issues with the HT calipers but I can't remember what they were.
