Wiring question.
Posted: Tue Apr 18, 2023 7:21 pm
Hi All, I have just sorted the original wiring harness on my Ek (repaired, some new terminals, re- taped ,etc) My question is - What wires pass thru the top grommeted hole on the pedal box? and do these wires pass up thru ( if it is the rear harness) or the main front harness pass thru to the underside.
I have also discovered that there is a difference with the brake/clutch master cylinder reservoir thread sizes after getting the lot sleeved with stainless. I thought the only difference was the shape of the rear flange where it bolts to the firewall. I wanted to keep with the long skinny shape rather than the later oval shaped ones. I will now have to dig out another one and get that recond . #&@# it. Regards Daz.
