transmission
BILLY BLACKARROW
transmission
Post by BILLY BLACKARROW »
Hi all
Doe's anyone know a formula to work out what gearbox gear (gear in gearbox ) to speedo to use for a 305 chev /turbp 350 i think the roll measurement may be needed but at this point in time that is unknown till tomorrow hope you know what i mean.
Billy
BILLY BLACKARROW
Re: transmission
Best way I've found is road test Billy. Not much help if you don't have a gear to start with. They usually have around 20 teeth. Each tooth you add slows the Speedo by around 5%.
WesternWagon
Re: transmission
Post by WesternWagon »
Few calculators on line that may help
Gazza
Member : Holden Car Club WA.
:ASRF Member
Re: transmission
You'll need to know what colour drive gear is already inside the box. You can then pick a driven gear to suit (can change both if needs be).
viewtopic.php?f=27&t=18598&p=189353&hil ... ur#p189353
Re: transmission
Billy , TCI transmissions website has a real good calculator, also tells you what colour the gears are so you can see the colour of your drive gear inside the box and try and match a driven gear to it - all you need to know is your diff gear ratio and rear tyre size , if you don’t know tyre height there is a calculator to work that out online too just Google tyre size calculator and put your size in and it will give you the height
BILLY BLACKARROW
Re: transmission
http://www.tciauto.com/tc/transmission- ... gears.html
Blacky I found the website you suggested but cant find the calculator
Harv read your earlier post ( a bit technical for me never was any good at math )
Where can i buy the gears locally any ideas
BILLY BLACKARROW
Re: transmission
Re: transmission
