hydo or trimatic
mattymartin
hydo or trimatic
Post by mattymartin »
hey team,
how can i tell if i've got an tri-matic or hyro-matic...
matty martin
go the wagons....
If you've got a red motor, I'd be 99% sure you'd have a trimatic behind it... but then again stranger things have happened.
Post by mrs ratbox »
when selecting gears if the first gear out of park is reverse it's a tri :D if reverse is all the way at the oposite end from park it's a hydro :cry: also if it is extra slow with horrible gear changes it's a hydro :lol:
mattymartin
tri or hydro
thanks team,
I'm picking up the car on sunday at noon... after i found out that it hasn't been touch for four weeks... (i'll check gear selection then)...
all i need done is the thing that stops the car starting in gear... and the thing put into the steering column that put reverse lights on & most important... the speedo, so i know how fast i'm driving...
mephious or any other sydney siders know of anyone that can help me out... or should i just take it to jo blow down the road...
matty martin
go the wagons....
ratbox wrote:when selecting gears if the first gear out of park is reverse it's a tri :D if reverse is all the way at the oposite end from park it's a hydro :cry: also if it is extra slow with horrible gear changes it's a hydro :lol:
:oops: :oops: Didn't even think of that, way too easy ratbox!
