Brass tail pipe
Posted: Wed Nov 09, 2016 7:17 pm
Pulled the tail pipe of my old FB just now and it appears to be brass from the muffler back. Image
It's not that obvious from the photos but I'm pretty sure of it. Image
Not sure you could squash a steel one like this without creasing it. Would have had a lot of back pressure. There is not a speck of corrosion where as the rear body has a bit. Image
I'm wondering if anyone has heard of this.
Re: Brass tail pipe
Posted: Wed Nov 09, 2016 9:56 pm
by Rusty EK
See if a magnet sticks to it and give it a tap with a grinder and see what colour it is .
Re: Brass tail pipe
Posted: Wed Nov 09, 2016 10:33 pm
It's brass. No rust.
Re: Brass tail pipe
Posted: Wed Nov 09, 2016 11:12 pm
by In the Shed
Geez if that's the case it be worth a few bucks in scrap value?
Re: Brass tail pipe
Posted: Wed Nov 09, 2016 11:44 pm
brass or copper ??? I seem to recall copper tailpipes were sorta popular back in the day .....
Re: Brass tail pipe
Posted: Thu Nov 10, 2016 7:56 am
Probably is copper then thanks Blacky. Never heard of this before.
Re: Brass tail pipe
Posted: Thu Nov 10, 2016 11:57 am
I had an uncle-in-law who ran copper tailpipes on a number of cars, no muffler. It was a little antisocial around town (near Newcastle), and not too popular with the local police. When needed, the exhaust would be packed with steel wool to quieten things down when putting around. Get back out of town, plant the throttle wide and the steel wool gets ejected pretty quick. I dread to think what smouldering steel wool would do in roadside grass :shock:
Re: Brass tail pipe
Posted: Thu Nov 10, 2016 12:29 pm
Thanks Harv. I wonder what the rationale was for copper.
Re: Brass tail pipe
Posted: Thu Nov 10, 2016 2:22 pm
I'm guessing relatively cheap and easy to get hold of (plumbing fittings), big bore, and able to be bent and soldered/brazed easily in a back yard.
Re: Brass tail pipe
Posted: Thu Nov 10, 2016 10:44 pm
Make sense. Seems to be 1.5" inside diameter. Certainly outlasted the rest of the exhaust which is just rust. Just goes to show there's always some thing to learn about these old jiggers. Thanks for your input fellas.
