Cable v's Linkage n Shaft
Posted: Wed Jul 04, 2007 4:30 pm
by Trev
I want to know if it's worth leaving the original linkage accelerator on the FB wagon with a red and trimatic, or just go for a cable setup?
Personally I like the look of the linkage setup, is there anything wrong with leaving it as is?
Posted: Wed Jul 04, 2007 4:37 pm
by Devilrod
Not if it works well and you don't mind cutting a hole in your new carpet..
The only bonus with a cable setup is you can position the pedal in a spot best suited to your driving position.
Posted: Wed Jul 04, 2007 4:50 pm
by Trev
Who ever set up the pedal in my sedan stuffed it up
, very uncomfortable,
Posted: Mon Jul 09, 2007 3:35 pm
by Trev
can anyone tell me why I shouldn't use the linkage setup?
Posted: Mon Jul 09, 2007 7:25 pm
by mrs ratbox
they're ugly
Posted: Mon Jul 09, 2007 8:46 pm
by Trev
Beauty is only skin deep, I never have my engine bay on display anyway, so who's gona tell
Posted: Mon Jul 09, 2007 11:40 pm
by ben
Trev, im keeping the linkage setup. for one if it ain't broke, and two don't mind the look either. i have snapped a couple of cables on the rally car, not that you generally drive your fb/ek in the bush, but i doubt there have been many fb/ek with the bonnet up due to linkages.
ben
Posted: Tue Jul 10, 2007 12:29 pm
by Devilrod
Ummm yeah
Add a flame thrower kit and standard pedal and you have a recipe for disaster and a really bad drive home. Although I did find that vice grips make a good substitute accelerator pedal!
And my brother has subtituted string for a cable (carefully run through a hole in the firewall). Was quite funny driving home....
Posted: Tue Jul 10, 2007 8:06 pm
by mrs ratbox
i was only trying to help, and that was the best i could come up with
here's a new one it's gunna be red motor? with no linkage you can set the motor back further
Posted: Wed Jul 11, 2007 3:56 am
by Trev
AH thats better, an answer that makes sense
, I didn't think of the space issue, thanks Trev
cable v linkage
Posted: Thu Jul 12, 2007 12:18 pm
by reddo
YO
the problem is that older strommys are set up so that the old linkage pull down on the outside edge of the carb or if it is an hD/Hr type it twists on the end of the carb so that the carb linkage rotates anticlockwise on application of the throttle when looking at it from the firewall.
with cable throttle onto a stromberg if you run the cable via the least "Bendy" route the cable comes over the rocker cover.
when you put your foot on the throttle the cable retracts.
which means the cable has to be set up so that it pulls from under the carb linkage and up towards the tappet cover.
You cant hook it to the top of the cark linkage it simply wont work.
I used a VC commodore cable and made a outer cable support fork that bolts onto a manifold stud and holds the cable via the outer cable adjustment thread. The inner cable comes down next to the tappet cover and onto the bottom side of the linkage . i made up a 6mmm bolt out of running thread to hold the nipple that the cable attaches to.
So... there ya go... clear as mud
end result is a really smooth throttle . probably would have been a bit less complicated if i had gone to the wreckers and bought all the gadgetry that bolts onto the carb and manifold of a VC Commy.
My ute is running a 186 which clears the firewall by about 12mm so cable was the way to go. I have run this set up since i installed the motor about 2 months ago. no probs. spent last night fitting the X2 carbs and manifold back on the car and used the same gadgets to get them opening properly when i stuff my foot into it.......... now if i could just get the 2 or 'em to breath properly at the same time instead of mucking up i will be a happy man.
Nothing wrong with the old system . Holden wouldnt have used it if they thought it was gunna give ya trouble. Its just mugs like me that mess with things god created that have troubles . But once the troubles are sorted it is a much smoother throttle. Devilrod is right in saying you can fiddle with pedal position to suit your driving style and comfort.
once happy with the position ya can be rough and screw it in place with a coupla self tappers or do it with a couple of captive nuts set into the floor.
Reddo
Posted: Thu Jul 12, 2007 4:22 pm
by Trev
Thanks for that Reddo, it doe's make sense now, cable is the way to go.
Although with the x2 setup the linkage would still pull towards the fire wall, so it would still work.
Posted: Thu Jul 12, 2007 7:12 pm
by mrs ratbox
you can use the linkage with the red, just if it's not there you have more room
Posted: Fri Jul 13, 2007 5:18 am
by Trev
Yeh, I recon that (space) would be the reason not to use the linkage, thanks Trev
