Grey won't start
Grey won't start
Set the dizzy.
Points gap.
Carby inspected, replaced float and set float level in bowl etc.
Gapped the valves.
Spark plugs gapped. New.
Got spark.
Got fuel.
Turns over but no start.
Any ideas please?
Points gap.
Gapped the valves.
Got spark.
Got fuel.
Any ideas please?
Re: Grey won't start
If you have spark and fuel it has to be timing ?
Simple, must go over that again.Blacky wrote:If you have spark and fuel it has to be timing ?
- Craig Allardyce
- State: VIC
x3 for timing
also:
Have you had the cam out?
What's the compression like?
Fresh fuel?
also:
Fresh fuel?
Last edited by Craig Allardyce on Fri Apr 01, 2016 9:10 pm, edited 1 time in total.
No the cam hasn't been touched.Craig Allardyce wrote:x3 for timing
also:
My mate bought it from a swap meet, heard it run there also a couple of weeks ago while in the car.
Not sure of compression.
Top dead center it again and don't go off the timing marks do it from the piston height. Make sure you are on the right stroke meaning the valves are closed and on the compression stroke. Put the dizzy in and with the ignition on rotate it until the points open and spark, make sure your rotor button is at number 1 lead lock it in. Check the leads are correct and you have them going the right way with the rotation of the rotor button. Now look down the carby and make sure fuel is going in when you pump it. Crank it over and it should run if everything else is ok.
Hope this helps if you haven't already checked it.
- Craig Allardyce
- State: VIC
153624
Thanks for you help bit this bitch just won't go. It's got me stuffed!
The closest it gets is sounding like it's about to go then nothing.
If it was my car I would be alot more pissed off.
Time for a compression test - anyone been playing with the valve train ?
Can you take it to a Mechanic. ?
We adjusted the valve gaps.Blacky wrote:Time for a compression test - anyone been playing with the valve train ?
Believe it or not it went to a mechanic running and came back not running.WayneXG95 wrote:Can you take it to a Mechanic. ?
Won't be recommending that guy.
Oh.....ShitTrev wrote:Believe it or not it went to a mechanic running and came back not running.WayneXG95 wrote:Can you take it to a Mechanic. ?
