HR disc brake front end
Posted: Fri Feb 26, 2016 9:47 pm
by Mick21
Does anyone know where I can get a HR disc brake front end?
Re: HR disc brake front end
Posted: Fri Feb 26, 2016 10:19 pm
by oz_ek
I see one on 'evil bay' in Melbourne, Looks a bit tired and rusty for $1100-
Posted: Sun Feb 28, 2016 10:48 pm
by Mick21
Yeah saw that one too. Bit rich for the condition it's in and then I still have to do full reconditioning.
Thanks any way
Posted: Sun Feb 28, 2016 11:28 pm
by oz_ek
Have you considered Torana discs on a drum brake HR front end?... The adaptor kit is readily available.....Only draw back is the conversion makes the track width a little wider.
Posted: Mon Feb 29, 2016 11:14 am
by DOLLER60
Better off with P76 discs and HQ calipers- narrows the track
Posted: Mon Feb 29, 2016 12:32 pm
by fb delivery
HR Drum brake front end $300
pick up Toowoomba
Posted: Mon Feb 29, 2016 12:56 pm
4 cylinder VB Commodore also an option if you want to retain 4.25" pcd as per FE - HG.
Posted: Wed Mar 02, 2016 5:13 pm
by Mick21
Wow, thats starting to sound a bit too complicated.
I'm in Melb so Towoomba pick up is a little far.
I'll either keep it original or just wait for a HR front end to appear.
Thanks
Posted: Wed Mar 02, 2016 11:20 pm
by In the Shed
There is one on Gumtree. Not sure what your budget is, advertised for $750 incl booster.
http://www.gumtree.com.au/s-ad/willowba ... 1105872639
Posted: Fri Mar 04, 2016 2:53 pm
by kelleigh54
Bought a drum brake unit with everything hanging off it for $150 a couple of months back , will be using HQ / WB spindle and rotor set up with rotors drilled to early PCD . Will do full rebuild and modify top A arm location to install in daughters EJ . There are sensible buys out there , personally I wouldn't pay more than $250 for a rebuilder .
Posted: Thu Mar 10, 2016 6:48 am
Not mine, though one for sale in WA, over at the Ozrodders site:
http://www.ozrodders.com/forum/viewtopi ... =9&t=61348
HR DISKBRAKE FRONT END
SUIT RESTORE
IN BITS READY..
$650 ONO..
0414066155
SMS FOR PHOTOS CANT UPLOAD..FILE TO BIG??????????????????
Posted: Wed Apr 06, 2016 9:19 pm
by KILRFB
Not sure if you are still chasing one but I have a disc brake version for sale as I have purchased a rodtech frontend. It is stripped down but complete and has had the hr outrigger removed. I have a brand new fb outrigger for it. I have done the lower cross member re-enforcement plate already. It comes with new ball joints replaced and about $400 worth of new parts not fitted. Will need new shockers and the callipers rebuilt. Chasing $800 no less. I'm in Kilsyth.
Posted: Wed Apr 06, 2016 10:41 pm
If anyone needs a HR front end in WA I have one you can have for a bloody sight less than $650 .......
