Poor man's heater recore
Hi everyone,
I've been quoted $200+ to recore a poor man's heater...
Any suggestions? (don't want an electric heater etc)
...apart from being a richer man?
Stewart
Re: Poor man's heater recore
You got PM :mrgreen:
The easiest way around this one is to use an oil cooler from SuperCheap (about $120):
http://www.supercheapauto.com.au/online ... 5647#Cross
I havn't checked the measurements, but it is likely to fit under the plenum without fouling. If not, the power steering cooler (part number 1009) probably will, and should be about $30 cheaper again:
http://www.daviescraig.com.au/Images/Ca ... 0tech1.pdf
http://www.daviescraig.com.au/Images/Ca ... 202011.pdf
Thanks Andrew. :thumbsup: Rang the place back - going to try and fix the leak rather than recore.
Craig Allardyce
Post by Craig Allardyce »
Hi Stewart,
what's leaking exactly? Is it the core or the heater valve? I'm assuming you have a warmaride unit fitted. If you have no luck I have a Hemco fresh air core that bolts directly underneath the plenum flap. It doesn't run a fan and relies on having the vent open to get air across it.
Its shown in the picture below.
Hi Craig
Thanks for that. No warmaride fitted -just a basic heater core as you describe. I'll see how I go with getting the one I have fixed. :thumbsup:
Stewart
Hi Stewart,
If you get desperate I may have a couple of those cores but can't look till tomorrow.
Thanks Greg :thumbsup:
Hi Stewart,
I have a couple but they are different, Have you got a photo of the old one ?
