At the traffic lights today, my cutch pedal started making a funny click noise when I pushed it in. I thought this may have been the spring under the dash, but this was found to be OK. When I let it out slowly, it goes click and the last part comes out fast (like dropping the clutch)
Could I have a torn or broken clutch fork??
Tony Takeoff.
Wonky FB clutch
Re: Wonky FB clutch
Could be lots of things from a loose slave cylinder to a dodgy actuator rod linkage under the dash I guess.
Engine off, handbrake on, work the clutch pedal whilst you get your head under the dash, under the bonnet, and then under the car to track the noise.
Alan
Member No.1 of the FB EK Holden Car Club of WA (Woo-hoo
sweet!)
Brian Westlake
Re: Wonky FB clutch
I will try this with Fi, saturday arvo after work (Try What???) I had the gearbox out of her EK 2 weeks ago. Here we go again! I wish I could say I was getting better at it. When I was young, I could pick up the gearbox on my chest, lying on my back on the grass. Now I seem to need a jack, still on the grass though! Drove my Tank Fairlane to work today. Seems to go well, and no gear changing, but fuel guage has dropped already!
Tony Testdrive.
Tony Testdrive.
Re: Wonky FB clutch
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>MeFB wrote: work the clutch pedal whilst you get your head under the dash, under the bonnet, and then under the car to track the noise.
Gotta have a long leg to do that mate ......
.........Fingers
Brian Westlake
Re: Wonky FB clutch
I could feel the "click, click" through the clutch fork under the car (with Fi pushing the clutch in as I have'nt got particularly long arms or neck Fingers L.O.L.) I pulled off the floor cover and small inspection cover on the top of the gearbox and found I could touch the throwout bearing and clutch fork from inside the car. Click, Click, but still no clue. So I pulled out the box and still didn't find anything conclusive, no broken clutch fork, throwout bearing seemed ok. I will check the pressure plate, but I don't think it's that. I'm putting in a whole different gearbox, clutch fork and springs, so I may never Know what it was. If the noise is still there, I will have to seek some form of mental help.
Tony Tailshaft.
Tony Tailshaft.
