304 ss motor
Posted: Thu Feb 23, 2012 6:14 am
by angela
Hi all can any tell me i picked up a vs ss 304 motor and box to run a carby what do i got to change do i change cam and dissy or can i slap a manifold and carby and go
Re: 304 ss motor
Posted: Thu Feb 23, 2012 9:45 am
by Ed
Manifold to suit the injected heads and carb.
you may need to change the dizzy if you aren't going to use the ECU, cam would be same for either carb of EFI.
Re: 304 ss motor
Posted: Thu Feb 23, 2012 10:06 pm
by Mick
do you have that motor/gearbox :?: if using that auto without computer associated with the injection etc i think can be a headache
Re: 304 ss motor
Posted: Fri Feb 24, 2012 3:46 pm
by RollinLow
Mick wrote:do you have that motor/gearbox :?: if using that auto without computer associated with the injection etc i think can be a headache
Chuck in a TH400 auto and its a heaps stronger box if its built correctly!
Re: 304 ss motor
Posted: Fri Feb 24, 2012 5:06 pm
by Cal
The trick is to use a VN or VP T700 gearbox, where everything associated with the gearbox like kickdown and stuff was mechanical, not electronic
