Stubtech drop spindles
ek amigo
Post by ek amigo »
Best wishes for the new year to everyone. just wondering if anybody can help me solve a problem. I have a Hr front end with 2 in stubtech drop spindles, HQ rotors , HQ calipers ,HQ steel rims, HR steering arms. There is 2 problems 1. the tie rod ends are mm's away from the tyres .2. the tyres are hitting on the gauards when you turn. Any ideas Gents. Is there some other steering arm that can be used, and if I get P76 rotors will that help with the tyre scrub.
wot179
Re: Stubtech drop spindles
Post by wot179 »
Machine some spacers up for between the steering arm and the stub axle,or fit narrower wheels and tyres.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
ekstevo
Post by ekstevo »
if your using the original steering box get some hk steering arms. use 14" 60 series tyers.
P76 rotors won't help as what ever it moves away from the guard it will move towards the as mentioned close tie rod end, skinnier wheels and bash or cut away the guard lip
ek amigo
Post by ek amigo »
thanks gents , is it possible to get a skinnier steel HQ stud pattern rim ? I have HT on the back which I noticed are skinnier than the HQ
depends which one you have there is a 5" HQ rim and a 6" HQ rim
ek amigo
Post by ek amigo »
excuse my ignorance gents but i though the rims only came in 6 inch . now i am on the hunt for 2 - 5 inch rims , should solve a lot of problems. many thanks gents
mainly kingswoods belmonts had the 5's statesmans 1 tonners etc had 6's as far as i know
bat53retro
Post by bat53retro »
use short hq / wb steering arms
ek amigo
Post by ek amigo »
thanks fellas should have it sorted with all that good info Happy New Year
vintageholden
Post by vintageholden »
sell them to me..
i,m after a set of hq drop spindles if anyone reading this has a set..
if there on your car and you dont like them..i can remove and replace for you..
