Page 1 of 2
Underway - 5-Speed Conversion
Posted: Mon Sep 26, 2011 8:35 am
by Mai Ki-Ki
What have I done....!
Old 3 speed is out, big hole in it's place, which is about to get bigger as I have to cut out a section of the tunnel / inspection plate / crossmember.
Won't be the same hump as the auto, so will have to custom fit the front carpet....and have a quite modified shifter to miss the front bench.
New 'hump' and crossmember to follow....
- IMG_2486.JPG (131.08 KiB) Viewed 2096 times
Here's the 5 Speed *sillycar* box and Dellows Adapter Bell Housing......
- IMG_2478.JPG (151.7 KiB) Viewed 2096 times
They sent me the wrong throw out bearing and clutch plate
so it won't be all together this week.
Stay tuned, full Step by Step How-To will follow....
Maiki
Posted: Mon Sep 26, 2011 10:05 am
by Devilrod
Will it make it in time for chopped Maiki?
Re:
Posted: Mon Sep 26, 2011 10:13 am
by Mai Ki-Ki
Devilrod wrote:Will it make it in time for chopped Maiki?
No way now.....started about a week too late.
Parts took ages to get here, and then had setbacks getting some muscle to help me mock up the box as it's 50kilos....oh well.
Re: Re:
Posted: Mon Sep 26, 2011 1:43 pm
by Devilrod
Mai Ki-Ki wrote:
.. and then had setbacks getting some muscle to help me mock up the box as it's 50kilos....oh well.
Shite thats heavy! Steel case huh? Shame you won't have it at Chopped.
Re: Re:
Posted: Mon Sep 26, 2011 5:20 pm
by Mai Ki-Ki
Celica Steel case = 45kg
Supra Alloy Case = 35kg
Yep pretty devastated....but will be done in a couple of weeks worst case I hope....be fun with 5-speed box.
Re: Underway - 5-Speed Conversion
Posted: Mon Oct 10, 2011 3:56 pm
by choppedfan
Maiki,
Hows the conversion going, I'm interested to get your opinion on how the 5 speed goes behind the grey, are you running a stock diff centre?? I ran a 4.11 gear set in the 9" diff in my old 28 Hiboy with a 5 speed supra box and had the best of both worlds, great acceleration off the mark and overdrive for highway cruising
Posted: Tue Oct 11, 2011 1:06 pm
by Mai Ki-Ki
choppedfan wrote:Maiki,
Had a two week break after not getting it finished for Chopped Car SHow.
Now there's a great big hole in the tunnel, and it needs a reworked x-member.....tail-shaft measured ready for shortening and the Toyota end added...
Hope to be bolting it all back together late next week.
Posted: Wed Oct 19, 2011 1:13 pm
by Mai Ki-Ki
Found out I need a red motor pressure plate (that apparently bolts straight up to the grey flywheel) then the Dellows clutch plate will fit.....
Driveshaft being shortened as we speak.
Getting there...
Posted: Sat Nov 05, 2011 4:38 pm
by choppedfan
Makai,
Are you back on the road yet???
Posted: Sun Nov 06, 2011 1:45 pm
by Mai Ki-Ki
Have this week to get it running...everything's in, just need to get the hydraulics set up and fill in the holes now.....!
Then i'll post the whole shebang!
Posted: Wed Nov 09, 2011 8:18 pm
by Mai Ki-Ki
Box and everything is in...!
Works a treat.....new cross-member built...just the hole in the floor to patch tomorrow.
F**King awesome.....shifter modified to miss the bench seat too.......
Posted: Wed Nov 09, 2011 8:20 pm
by Trev
Pics of your work?
Posted: Wed Nov 09, 2011 9:36 pm
by Mai Ki-Ki
Trev wrote:Pics of your work?
Will be some up hopefully tomorrow...if not friday.
Posted: Fri Nov 11, 2011 4:15 pm
by Mai Ki-Ki
Mai Ki-Ki wrote:Trev wrote:Pics of your work?
Would you believe Sunday...?
Box works a treat, tunnel 2/3 fabbed. Structurally sound, just needs to be fully sealed now before I put the carpets back in....Weird going from 3 - 5 gears!
Posted: Sun Nov 13, 2011 8:03 pm
by reddo
Hi Mai Ki-ki
Can you put up a few pictures of your gearbox mount.
I also have the 5 speed bolted up in place. Clutch works sweet.
Scored a trans hump on ebay off a bloke at Erskine park .
Its on its way.
Started to make the gearbox mount. .. would help to see a few photos of how you fabricated it..
Trying to make it solid to help make up for cutting the strengthened section out of the original floor pan.
Would like to put a "rib"on the bottom side of the trans hump too. ... all adds to stiffening things up in the floor pan.
Keep reminding myself that there is only the 2 engine mounts on the cross member and the one at the rear of the box holding all the weight.
I suppose it was just as flimsy when the grey was in there... one mount at the front.. 2 at the rear of the motor and the gearbox just swinging in the breeze with nothing supporting it...
I have a rear mount for celica to EH conversion but it is nothing like what is needed for FB/EK.
Maybe a few other members can stick a photo of their Celica gearbox mount conversion on here too..???
Reddo
